Changing Tire Size
Old Jun 23, 2010 | 04:09 PM
FiTTT's Avatar
Changing Tire Size
Say if you change your tire size to 205/50/16 and you get into an accident and its a total loss but you still have the GAP insurance. Will it void your GAP insurance since its not factory specs?
Old Jun 23, 2010 | 06:41 PM
Stormtrooper's Avatar
I would assume that depends on your gap insurance provider? This seems to be a question you may want to take to your agent, rather than a forum. Insurance and warranty disputes between a consumer and a provider happen all the time...
Old Jun 24, 2010 | 03:54 PM
mahout's Avatar
Only problem I see is if your changing tire size contributed to the accident. Tire diameter contributing to fender rubbing could be a culprit.
Old May 9, 2011 | 04:44 PM
SHEMP's Avatar
can i put a 205/50/16 tire on a stock 2009 sport fit wheel?
Old May 9, 2011 | 06:46 PM
Farther's Avatar
I certainly can but I have my doubts about you.
Old May 9, 2011 | 09:48 PM
Nukedog's Avatar
LOL...Tire size will not change anything insurance related unless it is stupid different...LOL
Old May 10, 2011 | 07:30 PM
specboy's Avatar
People running Stretched tires that do not fit the rims properly (Per the tire or wheel manufacturer's specs) or those that are running insanely high pressure "got sum splainin to do" but as long as the tires are inflated properly and are the correct FITtment, there should be no issues.
But as recommended, talk to your insurance company and if possible have them put it in writing. If they ask why, tell them you are paranoid and like to have everything on letterhead.
~SB
Old May 13, 2011 | 02:14 PM
Aitor's Avatar
I am thinking of upgrading my tires to 205/50 16. Is the recommended psi the same with these as before with the original narrower tires? I think it is 33psi.
Thanks.
icecreamstpete
Sep 24, 2018 02:03 PM
joepmac2
Mar 14, 2012 12:19 AM
BayAreaKid
Oct 5, 2009 05:55 PM
dcmcelreath
Jun 1, 2008 06:12 PM
Sugarphreak
May 24, 2008 09:10 AM
