Tire question.
Old Mar 12, 2012 | 07:59 PM
joepmac2's Avatar
Tire question.
I have an 09 Fit Sport. It is stock with no mods to wheels or suspension. I need to know if I can run 205/55-16 tires without interference. I don't care about speed difference etc. I just want to know if they will work.
Joemac
Old Mar 12, 2012 | 09:52 PM
solbrothers's Avatar
you should be fine. why so serious about this tire size?
Old Mar 13, 2012 | 07:35 AM
Funkster's Avatar
Should have no problems.
Old Mar 13, 2012 | 12:24 PM
joepmac2's Avatar
Thanks for the replies. Why am I so serious? Didn't think I was, just asked a question. I have read so much on tire size questions and all the off the wall answers to these simple questions that I just wanted a simple answer. Most of the tire size questions related to the 205/50/16 as being the tire to use if keeping the mph etc. as close as possible to stock. I would be open to larger tires than the 205/55/16 If they would fit. I am looking for a little smoother ride and could care less about handling.
Thanks again, Joemac
Old Mar 13, 2012 | 04:34 PM
eldaino's Avatar
well 55 series tires will keep the sidewall as thick as it is now. i just ordered some hankooks in 205/50/r16...i'll post em up and some impression once they are mounted and i have some miles logged.
Old Mar 13, 2012 | 04:47 PM
hayden's Avatar
The brand of tire you go with will effect this as much as anything. I just put on some continental DWs in 205/16 size and the car is smoother. The sidewalls on the stockers must be pretty stiff, because the car had better turn in, and lane change maneuverability than the new, much stickier ones.
Also to note, if you increase the diameter, and do not go with a lightweight tire (check the specs on them, they vary greatly) then you are creating a lot of rotational mass and unsprung weight. With the wheel/tire combo not wanting to change direction as easily, your suspension will not work as well, and thus you could end up with a less smooth ride due this weight factor alone.
Read reviews on tires to help with the lightweight/comfort decision. It's very noticeable from model to model, regardless of size. My new tires have a more pleasant pitch to them on the road too. They are a little quieter, but more high pitched. I think the ride is more comfy, as I mentioned.
Old Mar 14, 2012 | 12:19 AM
slp950's Avatar
I would go with 205/50-16 as well, or maybe 195/55-16 if you think you may lower it someday. 205/55-16 is HUGE compared to what came on the fits stock. Tire choice will play a much larger factor in ride than tire size.
icecreamstpete
Sep 24, 2018 02:03 PM
FiTTT
May 13, 2011 02:14 PM
bigpun54
Jun 11, 2009 01:51 AM
Sugarphreak
May 24, 2008 09:10 AM
Raaaaaaaaaay.
Nov 25, 2006 06:32 PM
