Tired of the Spoiler.
Old Aug 3, 2010 | 10:57 AM
z06dustin's Avatar
Originally Posted by Lyon[Nightroad]
Next time you are out cruising on the highway stick your hand out the window and estimate how many pounds of force are being applied to it. That force is even more important than the weight of the car.
Ehrm... not really, when talking trap speed. Aerodynamics is certainly a factor, but it's not nearly as important as weight.
Simple Horsepower Calculator
But like everyone else said, if is what you like, then do it!
I'd be more interested in MPG changes than trap speeds anyways, but then again I still have my spare and no nawwwwwwwwwwhhhhz.
Old Aug 3, 2010 | 11:30 AM
blackndecker's Avatar
Full interior? What's that?
Didn't realize you were stripped.
The stock alloys are 16lbs...
This is linear force on a bathroom scale. Rotational mass and unsprung weight are significantly underestimated by this method. You will see a much greater all around improvement by going with lighter weight wheels and performance tires than you will by removing the rear seat and tire. I removed an estimated equivalent of 280 lbs of interior weight by cutting 7 lbs of unsprung weight per corner...using the crude 10:1 rule.
Incorrect and a poor parallel. You are comparing the force applied to a flat hand perpendicular to the wind vs. the force applied to a spoiler that is parallel to the direction of the wind.
I can't think of anything on our car that would replicate your experiment....except maybe a strong crosswind hitting the side of the car, but even the side of the car is curved and rippled.
Old Aug 3, 2010 | 11:33 AM
^Agree
Old Aug 3, 2010 | 01:14 PM
Lyon[Nightroad]'s Avatar
I had my spoiler at about a 40 degree angle. I came up with the idea of removing the plastic spoiler clips and replacing them with a bolt and nut so you can adjust the angle. I should clarify that I would not expect someone with the spoiler at the stock angle to notice a difference.
Old Aug 3, 2010 | 01:53 PM
If it's not a busy day when I do go I will try a run or two with the spoiler and see if it affects my trap speeds. It probably wont affect ETs much but if there is a difference it will show in the traps.
If your goal is improve Trap speeds and ETs then why did you mod your spoiler to increase drag on the car and traction (albeit minimally) on the rear tires? Your spoiler has nothing to do with your trap speed.
1) Trap Speed will tell you about your HP to weight. <-- this is what Z06Dustin and myself were addressing.
2) ET will tell you more about traction and your launch. <-- why would you want to increase drag and rear wheel traction on a front wheel drive car...especially one that you are obviously attempting to drag?
Old Aug 3, 2010 | 01:55 PM
GREAT INFO BELOW...knowledge is power
Below is an article that I found that addresses the above information...I don't know the original source, but I found it here:
http://www.stangnet.com/mustang-foru...ined-here.html
Originally Posted by Stangnet.com
THE DYNAMICS OF TRAP SPEED VS. ET
After running lots of quarter miles, it becomes clear that how well you do in the first 100 feet of the track is KEY to a good time. The last half of the track is KEY to a good speed.
Let's use an example of a stick-shift mini-pickup that on a perfect run, gets a timeslip of 19.50 seconds at 70.00 mph in the quarter.
Imagine that the light turns green, the truck moves two feet and the engine dies for three seconds. After restarting the engine, the driver proceeds to then complete a perfect pass. His time slip would show 22.50 seconds at 69.97 mph. The ET was 3.00 seconds high but the speed was almost unaffected.. why?? It's because his racetrack was 1318 feet long instead of 1320, and in those last two feet this truck usually gains an additional 0.03 mph. However, the clocks recorded the long time. My point? Much of a great ET is made by a great launch.
Now take this truck again, and the driver leaves right on the green light. However, he misses the 3-4 shift when he's at 1250 feet. He coasts for the last 70 feet while trying to find fourth gear. Now instead of accelerating another few mph in this final 70 feet of the track, he decelerates over this distance. His timeslip; 19.51 at 67.83 mph. Note how the et is almost perfect (only off by 0.01 second) but the trap speed is way off (over 2 mph slow)! On a good run, traveling that last 70 feet at an average of 69 mph, would have taken .692 seconds. At a 68 mph avg., that 70 feet takes .682 seconds. That's why his ET only varied by .01 seconds, yet the trap speed was 'way off'. My point here: the end of the track is critical to trap speed; shift rpm, missing a gear... these are the big players.
Hopefully these examples are clear. Neither of these runs are 'perfect' runs, it's just that one has an error at the start, one at the finish and the results are obvious. The start of the track is a big player in the ET, but a small player in the mph. The end of the track is a big player in the mph, but a small player the ET.
So for the casual T-Bricks member who wants to get a HP value, you don't have to buy slicks, or wish you had a limited slip differential. You don't really need to heat the tires in the waterbox, or launch with huge power braking. As long as people get their shift rpm right and don't miss a gear, even a rookie will get the appropriate trap speed for their vehicle.. but honing the perfect ET. requires being rude to a clutch, buying steeper gears or slicks.... hey, we're trying to make this recreational.
OPTIMIZING SPEED
If your goal is to get a good trap speed, what are your options? More power, of course - and less weight is obvious (but it will come out in the power calculations as no increase in power). Shift rpm chosen (auto or manual) and the time it takes you to shift (with a manual) are probably the most important tools you've got. Try different shift points to maximize your trap speed. Reduce rolling resistance by pumping up all tires to their rated pressure. Some people think that running lower pressure might help the traction in the rear, though. Of course more traction will help et, but with most street tires, running street tires within 5 psi of rated pressure will provide you with maximum traction in the first place.
REACTION TIME
The ET clocks don't start until you've actually moved around 8 inches (this is called the rollout)... so don't worry about trying to leave right on the green light. You could wait 5 seconds after the light turned green, and still get a 19.50 timeslip in our truck example above. Your timeslip does show a separate calculated time, the "Reaction Time", which in this case would be 5 seconds. That is the time from the light turning green until you rolled out of the starting zone. It's not a big thing for our discussion here.
THE LAUNCH
For the most part, a decrease in ET is accompanied by an increase in trap speed, but don't go overboard on the launch in your zest to rule the world. Just try to get smartly underway without spinning the tires much at all. Traction levels usually drop a solid 0.10 g when the tires start spinning.
THE HP FORMULA
Here's the formula to use to calculate HP:
Net HP = Weight in pounds* (Speed in MPH/228.4)^3
As an example, Car & Driver tested the 744 Turbo in their June 1990 issue. The car weighed 3,081 lb. without the driver.. the 'race weight' was 3,231 lb. The car ran a 15.7 second quarter at 86 mph. Let's plug it in to the formula:
HP = 3231 * (86/228.4)^3
HP = 172 Net
Volvo rated this at 162 Net. We come out a little high. Or does Volvo underrate a little? I'll say this - I've used this formula for years and that's how the 228.4 was honed - actual experience from cars that had actual power curves - and when I use it on Volvos it tends to always come out a few percent higher than the factory rating. This could simply be that Volvo underrates just a little.
Still, for such a simple formula and such a simple test, it's surprising how accurate this can be. And the best thing is - there's no arguing the numbers on a timeslip. There are always differences between a DynoJet and an Eddy Current Dyno, or G-Tech numbers, but every setup is done by someone different and subject to error. The quarter mile is arguably the best comparison a diversely located group like Turbobricks will ever have. The only real difference to argue about is the altitude of the track! You can compare ET and mph all day and have a good discussion.
HANDY RULE OF THUMB
Once you have a baseline, you should probably use a rule of thumb that each additional 6 HP will give you another mph. That's for a 3200 lb car that runs 88 mph. If you want the real formula for different weights or speeds, here it is:
HP for another mph above "X" speed: = Wt * (((X+1)^3-X^3) / (228.4^3))
For instance a 89 mph quarter vs. an 88 mph quarter for a 3200 lb car:
HP delta = 3200 * ((89^3-88^3) / 228.4^3))
HP delta = 6.3 HP
Once you're going 110 in the quarter, it would take an additional 10 HP to go 111 mph in the 3200 lb car.
60 FOOT TIME
This is the standard measurement tool to evaluate your launch. It's the time that it took you to travel the first 60 feet of the track. Naturally, patterns emerge again after looking at lots of runs and of course these correlate best to time, not mph. Typically, most everyone's 60' time will be between 14% and 16% of their quarter mile time. If it's under 13% or over 17%, this was not your best pass.
1/8 MILE VS. 1/4 MILE
After monitoring tons of good passes, patterns emerge. Typically, the mph at the quarter is around 1.26 times of the mph at the eighth, and the time at the quarter is around 1.55 times the time at the eighth. You can use these values if you only have a 1/8 mile track and get a real good idea of the theoretical 1/4 mile.
IS MY ET TO SPEED RATIO REASONABLE?
One fact of the quarter mile is; no matter how slow or fast your car is, the mph multiplied by the ET will pretty much be the same number every time. Before the NHRA changed the way that speed is measured in 1989, the product of speed and time was around 1400. Let's calculate some easy examples of this. A 14.00 et usually resulted in a trap speed very near 100 mph. A 10.00 et meant around 140 mph. A 200 mph pass usually takes around 7.00 seconds. These are still good rules of thumb to remember, but now the product is more like 1380 for us - The example from Car and Driver above comes out at 1350. (The reason for this shift is explained below). Remember, most everyone focuses on ET so much that they'll even optimize a car for slower mph if it gets them a better ET. (Rear end gearing is one way to do this). Those guys tend to have a product closer to 1300.
RESPECT MORE SPEED - A LOT. EVEN 3 MPH.
If you look at the formula again, you'll note how trap speed shows up as the cube root of power to weight. That's critical to understanding how fast one car is over another. Let's say your car does a 90 mph quarter and the guy who raced you in the other lane ran 71 mph. After the race, he wanders over to you to say the 'race was close'. Your reply: "I could have towed you and still smote you". (This might not be the best way to make friends, but yes, it is TRUE if the cars weigh the same.)
Do the math. (90/71) cubed is 2.04. Yes, the 90 mph car has 2.04 times the power to weight of the slower car. It has 2.04 times the acceleration of the slower car. It's just that the track is a fixed length, and in accelerating to higher speeds, you use up the track quicker. You accelerated to 90 in about 20% less time than he had to accelerate to 71, right?
Bottom line; Down where most of us run, a 3 mph difference between two cars is NOT a race. It was a clear win. There's a full 10% difference between these cars.
SOME MAGAZINES SHOW THE CONSTANT AS 230.5 OR 234.0. WHERE DID YOU GET 228.4?
Some people try to correct to different things. Like Gross HP instead of Net. But most commonly, these other constants that you'll see in magazines were originally published before 1989 when the NHRA changed their lights, and the 'new' journalist doesn't realize the formula should change accordingly. Here's what I mean; previous to 1989, there were three timing lights at the end of the track; one AT the end of the quarter mile, and one 66 feet before, and one 66 feet after. The middle light was used to calculate the et of the run, and the time to travel the 132 feet at the end of the track was used to calculate the trap speed. This gave the average speed at the end of the track, but you can see what this lead to. Most of the racers stayed on the gas for an additional 66 feet past the quarter to get a consistent speed to evaluate their setup. The track's 'shut down area' of course is a fixed length, but the pro racers were starting to hit 300 mph plus by the end. In an attempt to get these guys off the gas 66 feet earlier and 'make' the cars appear slower, the NHRA stopped using the last light around August of 1989. Today, the trap speed is calculated between the light at the quarter mile and the one 66 feet before. So any timeslip after 1989 is really giving the average speed 33 feet from the finish, which is pretty close to one percent slower than before. The old constant of 230.5 became 228.4 to compensate.
CORRECTING FOR ALTITUDE
If we were dealing with non-turbo cars, this would be easy and we'd publish a formula. But with pressurized cars, the correction factor for altitude depends on the boost you run.
For instance, Sea Level air pressure is 14.7 psi. If you go to a track in Boise, Idaho (2850 feet above sea level) the air pressure is now around 13.25 psi. That's 90.1% of sea level pressure. If the temperature doesn't change and you have an normally aspirated car, your power output will now be 90.1% of what it used to be, so I'd tell you to correct by multiplying your calculated HP by an extra 10.9% (1/.901, or 1.109).
However, (and this is the beauty of turbo cars!!) Let's say you were running 10 psi of boost in the first place. So at sea level, your car was really getting 24.7 psi (14.7 + 10). Now you leave the wastegate at 10 psi and race at Boise. Your manifold pressure is now 23.25 psi (13.25 + 10). Note that YOUR power isn't down as much.. it's down to 94.1% of what it is at sea level. So you should correct with an extra 6.2% (1/.941, or 1.062).
If you wish to calculate your own correction factor, here is a handy table of elevation (feet above sea level) vs. standard day atmospheric pressure (psi):
0 14.70
500 14.43
1000 14.18
1500 13.92
2000 13.67
2500 13.42
3000 13.17
3500 12.92
4000 12.69
4500 12.45
5000 12.23
5500 12.00
6000 11.78
6500 11.56
7000 11.34
7500 11.13
8000 10.91
8500 10.71
9000 10.51
9500 10.30
10000 10.11
Yes, the detail oriented will notice that I'm ignoring lots of small effects of higher pressure ratios in the compressor, lower density air across the intercooler and even the fact that there's less wind drag at higher altitudes, and they're right. However, the overall concepts above still hold true.
There's lots of discussion of 300, 400, even 450 HP on the Tubrobricks list. It would be great to see these power levels turn out to be true. Just keep in mind that an honest 300 Net HP in a 3200 lb volvo (includes driver) will go just under 104 mph in the quarter. 400 HP would push it 114 mph, and 450 HP should propel the car to a trap speed of nearly 119 mph at Sea Level!
In terms of the ZO6, that makes for 19% less power at 5500' ASL (typical denver, there's a reason it's called the mile high city), so instead of 405 hp, they're making closer to 328 bhp.
If anyone else argues the point of how turbo cars are less affected by elevation than N/A cars without reading the exhausting long quote above, you are not only lazy... but an idiot as well.
Old Aug 3, 2010 | 10:11 PM
specboy's Avatar
Of Note, Most spoilers on cars are not for down-force. That's the EVO/STI style spoiler and they do make a difference when up at speed... and by speed, I mean speed. The spoiler on most cars like my old GS-R and likely on the fit were more for creating turbulence behind the car which prevents suction and prevents drag. It's more like the little lip wing on the hybrids or on the RSX-S (after the MMC).
~SB
Old Aug 3, 2010 | 10:28 PM
ThEvil0nE's Avatar
spoiler = is what it is... a "spoiler"
wing = down force
Old Aug 3, 2010 | 10:47 PM
mav238's Avatar
Yup, its your car, and you can do whatever you like with it, don't care what others say!
BUT I hate the look of it... JMHO... After spending $17000 on it, I don't think I would go around and experiment with it, removing stock factory accessories, and having holes left in the sheet metal. Even though you plugged it, the probability of it rusting there now has incresaed significantly.
BUT IT IS your car...
Old Aug 3, 2010 | 11:21 PM
~SB
Agree...but if you take a typical factory spoiler and "mod" it to increase the area in contact with the wind (see his prior thread), then you are increasing drag and increasing downforce on the rear end.
Old Aug 4, 2010 | 07:32 AM
specboy's Avatar
Downforce on the rear end of the fit won't mean crap until you are up around 140mph. These Touring wings that Ricers throw on their cars are for looks only and have no value because they don't actually do anything (except create drag, add weight, and slow the car down a minute amount).
also pointing a factory wing down means that you are no longer utilizing it for what it is intended and negating the good that it was doing. by modding the rear wing, you've probably increased the amount of drag due to suction and created 0 additional usable downforce. you may have added downforce but until you hit really high speeds, you don't need that downforce and wouldn't be able to see the benefit of it.
~SB
Old Aug 4, 2010 | 08:24 AM
  #32
555sexydrive's Avatar
BND,
Just skimmed through your paste job, this doesn't seem right to me...
I was at work all day and feel a bit tired, but how would an average speed slower actually net you a quicker time in that last 70'? Maybe I am somehow overlooking it, but if I'm not, did anyone catch that on the Mustang forum you grabbed it from?
Old Aug 5, 2010 | 03:24 PM
  #33
jondotcom's Avatar
Originally Posted by whaap
It's your car. Don't listen to what anybody else has to say !!!
Especially me. It looks horrible without it. Worse than a strippo mini-van.
Old Aug 5, 2010 | 05:23 PM
  #34
Yes, It does look ugly and probably has no good effect on the car.
Old Aug 5, 2010 | 06:22 PM
  #35
Old Aug 5, 2010 | 06:29 PM
  #36
So, do you think then that increased drag would lower your trap speed? It will. But, because drag isn't a big factor until you are at higher speeds, it will hurt your trap speed more than your et.
I fully understand the relationship between hp and weight and traction and ambient temperatures and elevation and its effects on et and trap speeds. I just don't think you understand how badly drag affects a low hp car. You can remove 300 lbs from your fit but it will only improve off the line performance. On the highway when trying to pass at 70 mph, it will still be a dog.
Anyway, this was before your time, https://www.fitfreak.net/forums/2nd-...oiler-mod.html and I didn't care about going faster back then.
Old Aug 5, 2010 | 06:31 PM
  #37
Krimson_Cardnal's Avatar
Lyon Win-place-show, sometimes you just never know, but you do find out.
I admire your daring.
Old Aug 5, 2010 | 06:41 PM
  #38
The base model has no spoiler and is only marginaly lighter but gets more mpgs.
Old Aug 5, 2010 | 11:12 PM
  #39
I think we are kinda saying the same thing...I was talking more in reference to your spoiler mod (which I had previously seen BTW...) than I was about the new spoiler-less look.
I'm a fan of the spoiler-less look...it would look better if you found some way to fill in/conceal all the remaining holes IMHO.
Old Aug 5, 2010 | 11:39 PM
  #40
BND,
Good pick up...it would appear that he reversed the speeds. There was a single post that kind of disregarded the article...basically without rhyme or reason. Everyone else was pretty enthusiastic about it.
This part reminded me of something I read recently:
HP = 172 Net
One of the import mags this month performed a "mythbuster" on the OBD2 Iphone app that, among other things, can calculate HP. The numbers they got were pretty close...about a 6.8% difference between Iphone app vs. dyno. I wonder if the reason for the discrepancy is the same? (i.e. dyno HP will always very slightly from calculated HP)
Sorry for the thread jack....
Jhoutz
Nov 22, 2018 05:01 PM
Press Fit
Aug 26, 2018 02:27 PM
Lyon[Nightroad]
Jan 23, 2017 07:17 PM
fittinIn
Jul 4, 2012 12:56 PM
SSM0423
Sep 5, 2008 10:40 PM
