"sighing" sound
Old Sep 5, 2010 | 03:42 PM
drooartz's Avatar
"sighing" sound
My Fit is a 2009 with about 35,000 miles on it.
Ove the last few months I've noticed what can best be described as a "sighing" sound. Duration is short, maybe 1.5 seconds. Starts louder than gets quieter.
In addition there is just a bit of a "grinding" sound -- usually under acceleration. Soft but present. Imagine a thin metal disc that is spinning, then touching another metal surface side to side.
These two sounds are quite possibly related. Most notable at lower RPM (say, 2000).
Any ideas? The noise is not completely consistent so it is hard to have a tech diagnose it. I did a looksie around the engine bay and nothing seems amiss.
Old Sep 5, 2010 | 10:29 PM
shegetstodriveit's Avatar
I've noticed a short hissing sound when the AC condenser kicks on. I've never noticed it in any other car.
Old Sep 6, 2010 | 04:10 PM
drooartz's Avatar
I did think it was AC related -- but it happens if the AC is off or on.
Old Sep 6, 2010 | 04:13 PM
hrmmm... I'll start listening more when I have the AC off.
you surely know... but the AC automatically kicks on when the fan is on and the defrost vents are chosen.
Old Sep 6, 2010 | 06:23 PM
Steve244's Avatar
check your front brake pads.
Old Sep 7, 2010 | 12:29 AM
reako's Avatar
Yeah that hissing is bothersome. I had it checked out and they basically said 'whatever I'm hearing' must be normal, because it passed all tests. One of the very few gripes I have with the car.
Old Sep 7, 2010 | 11:07 AM
That's disturbing. The dealer can't even admit there is a noise, since there is no error code.
On one hand I appreciate the dealer not simply making something up to try to explain it (condenser kicking on) when they don't really know. But on the other hand it is dissapointing that the technicians don't have a clue past what the maint manual and the idiot errors are indicating.
Old Sep 7, 2010 | 12:52 PM
Steve244's Avatar
"passed all tests" I took to mean a pressure check on the A/C. I think they must have done more than check for codes even if it was just listening to it in operation.
Old Sep 7, 2010 | 01:09 PM
Texas Coyote's Avatar
With a car as small as a Fit the sounds from under the hood are easily heard due to the proximity of the mechanicals to the passenger compartment...
Old Sep 7, 2010 | 10:05 PM
drooartz's Avatar
I must admit I hadn't really thought of that... I'm sure I read it in the manual when I bought the car, but that was a lot of miles ago.
I've an appointment on Friday with the dealer. I'll keep in mind the brake pads as well. Had something somewhat similar on my last car, it turned out to be the brake disc shield hitting the disc ever so slightly in some circumstances.
Hopefully it will make the sound for them. I *hate* diagnosing intermittent sounds.
Old Sep 7, 2010 | 10:16 PM
skinny's Avatar
i hear it when accelerating hard or fairly hard...it seems like a normal thing for me. doesn't bother me at all, car runs great and i really don't think its a problem at all.
Old Sep 8, 2010 | 02:01 PM
Farther's Avatar
Sounds like a Honda orgasm!
Old Sep 8, 2010 | 03:12 PM
vinn's Avatar
Seems normal to me, I get it too
Old Sep 8, 2010 | 07:04 PM
weeladdie's Avatar
My previous car, a Hyundai Elantra GT, made the same sound when the a/c kicked in. Don't know if it was the compressor, fan, or some valve or other in the a/c system.
Never seemed to cause any problems though....
Old Sep 9, 2010 | 12:07 AM
red600's Avatar
Beyond the a/c you may also want to check the intake and pcv valve. If the intake or pcv system has a gap/loose section that could be the reason for the sighing/hissing you're hearing.
Old Sep 14, 2010 | 04:08 PM
drooartz's Avatar
Well, I was able to (mostly) get the sound to happen for the dealer, but they didn't have any ideas. They did drive a new one and couldn't get the sound to happen. Said they'd "call engineering" which I take to mean they don't have a clue.
I'm not too worried about it, so for now I'm just going to keep an eye on it and drive. Did take the opportunity to get the MPG TSB done, so at least the day wasn't a waste.
Thanks again for all the suggestions.
ChuckDustin
Apr 8, 2019 12:09 AM
Poundsfitted
Nov 23, 2017 04:32 AM
Fit09Sport
Jun 12, 2017 06:39 AM
D50boy
Oct 1, 2015 06:50 AM
spin out
Sep 3, 2009 12:51 PM
