Ray's SSM GE8 Base/Sport Progress
Old Mar 8, 2011 | 06:47 PM
  #41
Goobers's Avatar
Originally Posted by Ray731
Today (thanks to my brother) was very productive! We installed my DZ springs! OMG it was so much easier than I thought but the fronts still took a while.
The difference with the rear springs was noticeable too!
-Ray
Is it me, or does that say "Swift"?
Nevermind... Took a closer look, I think it says 150LB...?
Originally Posted by blackndecker
Perfect! Nice job....LCAs are parallel. Your car really looks great at that height.
I don't think they're parallel, they look like they have slight angle. But I think angle is less than the angle mentioned in your previous post (it said something about having them intersect 40-60 mm off the ground).
Old Mar 9, 2011 | 12:04 AM
  #42
Ray731's Avatar
It actually says 1001F which I thought was a Part Number by the manufacture.
As far as the LCA's go they look parallel. No actual measurements made. The car definitely handles MUCH better IMHO.
Old Mar 9, 2011 | 12:38 AM
  #43
Ray731's Avatar
Originally Posted by Dr. Unsped
looking good! was debating those tails myself, the black base headlights look good but i have always thought they clashed with the rears being all chrome.
Thanks! Still working on $$$ to get those Mugen sides. Life keeps happening. Life emergencies keep depleting my cash flow! Why is the Mugen kit so much $$$! lol Come on tax refund!
On a side note I have been putting off the rear view mirror cover until I get the ones for the side mirrors! Color matched sport mirror covers...
Old Mar 9, 2011 | 01:10 AM
  #44
Hootie's Avatar
Hey, when did thread show up? The Base is looking good man!
Nah Ray, keep the Base mirror covers. Those and the factory black headlight housings are two thing that I really dug on your Fit.
Also, earlier in the thread you mentioned something about being surprised for not rubbing. Excluding the wheel offset, I think that is due to you having a shorter tire (205/40R17 if I recall) than what would be typically ran on a 17 (which is 205/45R17).
Old Mar 9, 2011 | 01:26 AM
  #45
Ray731's Avatar
Thanks! I too like the way the colors work together but I can't see putting the interior mirror cover on if the outside ones are black. I'll test fit it and take some pics to see how it looks.
I was more concerned about the inner fenders or other clearance issues. Same size wheel/tire combo on a 95 DelSol rubbed on turns all the time! Inner fender turning either way. No hard turns with that car... I had no idea how it was going to turn out and when I lowered it I was concerned again. I tested lock to lock turns and hard turns at varied speeds and verified no rubbing. The thing about the tire size is that even after the springs I still have a bit of a gap between tire and fender opening. Overall I'm happy with the springs! Looking at test fitting some 18's. I won't be buying wheels till the Mugen kit is on. I gotta watch how much $ I spend at a time...
-Ray
Old Mar 9, 2011 | 02:39 AM
  #46
Dr. Unsped's Avatar
one thing i've thought about, running no side trim but having splashgaurds painted to color match, im assuming the body shop could use some plasticizers or similar to get it to stick. the mugen sides are kinda neat but i do like the look without them too.
Old Mar 10, 2011 | 07:37 AM
  #47
Ray731's Avatar
With all the black on the car I don't think I'd bother painting them. I need to decide so when I have the money I don't stall like last time. $ goes away so quickly sometimes.
-Ray
Old Mar 29, 2011 | 09:37 PM
  #48
Ray731's Avatar
Seems like its been forever...
Wow it seems like forever since I got to do anything to the Fit. Too much work I guess. Well, I got some new tires today Falken Ziex ZE-512 ! Tomorrow off for alignment. I was a little disappointed to find out the wheels couldn't be touched up while the Fit was at the shop. He didn't have the right color to match. Oh well that's just less money to spend I guess. Found out my wheels are 28 lbs each! HOLY $#*%! I found out that if I decide to track the car I will switch to 16" Drag DR-9's they weigh 16 lbs each and I can get some good track tires on 16's but that's next year. Right at a grand for mount and balance is not too bad for inexpensive lightweight wheels and tires!
Drag DR-9
BF Goodrich g-Force T/A KDW NT
Here are pics of the new tires I got!
-Ray
Old Mar 29, 2011 | 10:31 PM
  #49
blackndecker's Avatar
If youre looking for dedicated track wheels...then why not get 15" wheels? You'll get better acceleration (the lower diameter is equivalent to increasing the final drive), lighter weight, and a much better tire selection (and wheel selection).
16" is an odd size for track duty.
Old Mar 30, 2011 | 09:11 AM
  #50
Ray731's Avatar
The main difference was tire choices. There was a 2 lb difference with the DR-9 15" to 16" according to there computer and no track worthy tires in the "correct" size for the 15" rim. I know I don't have to stay with the same overall size tire. Maybe you could throw some tire ideas at me for the 15" rim. I'm not against it, just was advised to go to 16" for tire choices. Going from 28 lbs to 16 lbs per wheel would make a huge difference for me. I plan on doing both wheels/tires and coil-overs next year. No extreme modifications IE engine or extreme weight reduction until warranty is expired.
Here is a link to the wheel I'm looking at.
Drag DR-9
Thanks,
-Ray
Old Mar 30, 2011 | 11:23 AM
  #51
Drag DR-9
Thanks,
-Ray
First off, those are nice looking wheels. I'm not a fan of the red lip...but that's just personal preference.
The extra 2 lbs weight reduction (unsprung weight) per corner going from 16" to 15" would be HUGE!!! Going with a 15" tire would also reduce weight an additional 1-3 lbs over a 16" tire (depending on size, specs, and manufacturer).
If this is strictly for auto-x, grip trumps all other considerations. My car accelerates very quickly (relative to other Fits)due to the lightweight wheels and smaller overall diameter...however, the top end lags and this would not be an ideal set up for a high speed track. If that will be your primary use, a 17" wheel would be a better choice.
And, you have to be kidding me that you can't find track tires for 15" wheels?!? Ask in the track/auto-x subforum. I'm sure they could give you some better info. You could also search tirerack.com and read their extensive tire reviews. Dunlop direzza star specs always come up at the top of a short list of outstanding auto-x tires. Hankook has a new lineup (ventus) that has also gotten some great reviews.
Good luck. Car is coming along nicely.
Old Mar 31, 2011 | 12:23 PM
  #52
Ray731's Avatar
I meant @ the tire shops locally. I know I can order just about anything online. I've found some that I like but they are much smaller overall height than stock. I will do my research. I'm doing this next year. (unless $$$ falls from the sky)
Here are some I like 16" tires lighter than 15"
Untitled Document
-Ray
Old Apr 1, 2011 | 12:43 AM
  #53
Dr. Unsped's Avatar
wouldn't your base steelies work well for track day?
my fit is in the same config yours is right now after i took my mugen sides off. i like the mugen stuff but the mugen sides with the sport front is bugging me and i know if i put the mugen front on it won't be long until i buy the rear, grill, and rearview cover ... and i'm not sure i want to do that.
i have a few ideas for mounting the sport sides on a base and hopefully someone will trade + cash for my mugen sides. if you can wait i might have a mounting solution for the sport sides on a base....
Old Apr 1, 2011 | 01:06 AM
  #54
Ray731's Avatar
You took the sides off?!? Well I prefer the Mugen ones over stock... Come on $$$!
Good luck with the install!
-Ray
Old Apr 1, 2011 | 01:29 AM
  #55
Dr. Unsped's Avatar
couple of things that bug me about the mugen stuff:
1) the sides tape to the front fender also, it would be tough to remove the fender without removing the sides and all it's adhesive. as i found out with removing the sides, replacing the 3m tape is a PITA.
2) how the front entraps the fog lights, crack a fog and you have to pull the fog light out the hard way through the engine bay.
3) what happens in 3-4 years when your in a fender bender and need to get replacement mugen parts, will they be available?
4) clearance
5) say i want to keep the car 5+ years, will the mugen adhesive and mounting methods hold up?
don't get me wrong, there is still a decent chance i will end up full mugen just some of the details bug me a little. i mainly took the sides off because i wanted to see what the car looked like with a sport bumper and rear spoiler and no sides ... and honestly i think it looks pretty good but it still bugs me a little. i think full sport or full mugen are the ways to go....
Old Apr 1, 2011 | 06:03 PM
  #56
Ray731's Avatar
I agree... Waiting on cash for Mugen sides. Then front, grill, and back. I might wait till I have all the parts before I mount stuff...
-Ray
Old Apr 7, 2011 | 10:03 PM
  #57
Dr. Unsped's Avatar
passing the base to mugen torch to you, just sold off my stuff and finished with the sport sides. you might check out pattypeck on ebay or call pat in person for the best prices i've found on mugen parts. look forward to pics!
Old Apr 7, 2011 | 10:42 PM
  #58
Ray731's Avatar
You got pics of that install?
-Ray
Old Apr 7, 2011 | 11:10 PM
  #59
Dr. Unsped's Avatar
Old Apr 13, 2011 | 12:07 AM
  #60
Ray731's Avatar
Well had a little mishap the other day...
I went to look at the 2011 Fit for 0.9 APR and to check if I'm on the recall list and apparently overextended the rear suspension along the way there. I have always wondered if this could happen with just lowering springs but I have never had this happen on any other lowered car. Yes I was hauling ass and yes I went over an unexpected large bump but I didn't notice it till I walked away from the car. Jacked it up and put the spring back in place. Man I need coil-overs!
Here are a few pics next to a new 2011 sport.
-Ray
