Does this void my warranty on my fit?
Old Dec 11, 2010 | 07:14 PM
superstitch626's Avatar
Just thought I would leave this here.
Old Dec 11, 2010 | 07:40 PM
AllBlkEvrythng10's Avatar
Lol-I love seeing pics of Honda's towing things, its so unconventional. +10 points for using a feature of the car that not many others ever do.
Old Dec 11, 2010 | 07:45 PM
Light-Weight's Avatar
I wanna coke machine.
Old Dec 11, 2010 | 08:13 PM
Goobers's Avatar
hum... I'd rather have a Pepsi machine.
Unless you're in Europe... they tow things all the time with small cars. Honda UK has an official tow hook accessory for the Jazz (aka Fit).
http://www.honda.co.uk/cars/_assets/...ries_final.pdf
Old Dec 11, 2010 | 09:03 PM
@ Light-weight i got it off some guy on Craigs list for $120
@Goobers Coke is the only way to go........also it was the cheap way to go lol.
Ever since i got the tow hitch i have been going to town.However, i mainly use it for a rear bike rack.
Old Dec 11, 2010 | 09:44 PM
Wow! That's a good deal.
Old Dec 11, 2010 | 10:29 PM
mahout's Avatar
You might want to search posts for the rear shock relaced with air lifts to improve the handling when towing.Theres a good set of them.
Old Dec 11, 2010 | 11:50 PM
solbrothers's Avatar
also, if you have an autotragic, i hope you have a trans cooler!
Old Dec 12, 2010 | 01:21 AM
Texas Coyote's Avatar
The last 2 fellows are right.
Old Dec 12, 2010 | 01:46 AM
@ mahout where is said thread?
@solbrothers I have the 5 speed so I think I am good....right?
Old Dec 12, 2010 | 02:04 AM
https://www.fitfreak.net/forums/fit-...ghlight=Shocks I hope this helps you out... I have done this to my car with good results.... Manxman did a great DIY thread when he put this together.
Old Dec 12, 2010 | 02:52 AM
mtsredni's Avatar
He's right! Had the Monroe air shocks on my GD 3 for a couple of years.
Pumped them up once to about 55± and hauled pre-cast concrete mantel & column pieces with them. Apprx 1000 lbs made railroad crossings nervous and steering was "rather strange" but made it to the job site with much relief.
Old Dec 12, 2010 | 03:54 AM
with 5 speed you should be good. but for those with autotrans, gotta get a trans cooler
Old Dec 12, 2010 | 04:15 AM
mtsredni's Avatar
I should add, anything above about 27 lbs on my car started to jack up the rear ride height. So for A/X I found them of limited benefit. I ran them as firm as about 36 but not beyond. They are great for hauling/towing though and, hey it's just fun to see peoples' faces watching you pump compressed air into the under side of your rear bumper.
All Fit automatics in 1st gen came w/factory AT fluid coolers. I know how much it costs to repalce one. Not a small number.
Old Dec 12, 2010 | 07:31 PM
thanks guys you have given me plenty to think about. when i have been hauling stuff i just put the load in the center of the trailer to make sure there was as little tongue weight as possible.
Old Dec 12, 2010 | 08:08 PM
jdotvo's Avatar
thats great. i'd love to have a coke machine myself.
Old Dec 12, 2010 | 08:33 PM
Virtual's Avatar
I'll have a Coke!
Btw, the automatic is also a 5 speed so to be more precise, it should be called a manual or standard transmission.
Old Dec 12, 2010 | 09:11 PM
DiamondStarMonsters's Avatar
Noticed auto trans coolers were brought up... for track use or towing they are a great idea, and they are NOT expensive.
The "expensive" bit is finding adapter fittings, and even that is not bad, there are all sorts if you go through Jegs or Summit.
Once that is done, select a larger cooler, pick up some braided SS lines and -AN fittings. Install the new cooler, and mount a switchable fan to it.
Derale Series 7000 Tube-Fin Transmission Cooler Kit w/ Hose Barb Inlets - Class II - Standard Derale Transmission Coolers D13106
Slim Radiator Fan
http://www.frozenboost.com/product_i...e30ef971939739
Old Dec 13, 2010 | 01:03 AM
Originally Posted by Virtual
I'll have a Coke!
well yeah, but when someone says 5 speed, it generally refers to manual transmission
sooznd
23
Jan 20, 2015 12:08 PM
dave92029
Oct 19, 2014 10:26 PM
alanchan
Sep 27, 2012 01:43 PM
txmatt
Sep 12, 2008 02:58 PM
jhoprodie5
Mar 12, 2008 12:20 AM
