Will it rub?
Old Dec 15, 2010 | 07:41 PM
circa40's Avatar
Will it rub?
I was just about to lower my car today but noticed my tires stick out more then the fender opening. The wheels are +43 and the tires are 205/50/16.
I also took some measurements and from the bottom of the fender opening and the top of the tire it's already about 1.5" The springs that I bought are Tein S-tech (about 1.5" drop). I just dont want to install the springs and have to remove them again.
The ruler is flushed to both top/bottom points of the tire
Any thoughts?
Old Dec 15, 2010 | 09:50 PM
jdmjunkie561's Avatar
Na dude ull be fine ! I had those springs before and the same size tires !! You good !! Only way u will rubb is if u doing over 100 on a big dip on the highway
Old Dec 16, 2010 | 10:33 AM
circa40's Avatar
Cool, that makes feel a lot better about my purchase. +1rep
Old Dec 16, 2010 | 12:35 PM
GD3_Wagoon's Avatar
that's all it takes for rep nowadays?...
when i had my gd3 i was on eibach sportlines which have the same drop as tein's do except the rear had a lower drop. my wheel/tire size was 15x7 +40 on 205/50/15 and i rubbed -- front and back. the rear rubbed a lot, especially with passengers. GE fender wells are larger but the larger wheel with the 205/50 tire profile has the same space to wheel/tire ratio compared to my GD with the 15' wheel and 205/50 tire.
for the front i needed to pull back the fender lining and camber the wheels -1.5 degrees, the rears needed a mild roll. this was the most affordable way to fix the rubbing: camber bolts were $20 on amazon, alignment was free (lifetime alignment at america's tire FTW), and a friend of mine rolled my rear fenders for free.
luckily for you, you're in the center of all the socal FitFreak active users. most of them live in the south bay, OC, and SD area and are always willing to help! stop by the local forum and say hello
good luck
Old Dec 16, 2010 | 01:18 PM
thefit09's Avatar
good luck
haha this is funny, because I just read on another thread how you didn't like fitfreak anymore because all people did was ask about wheel/tire combos rubbing, so you decided you'd stay on the local forums.
Can you say two-faced?
Old Dec 16, 2010 | 01:20 PM
thefit09's Avatar
For reference:
GD3_Wagoon hello, welcome back! i remember your Fit too, it was TW right?
i remember mike too, i bought his pro-c's when he sold his Fit for the MS3
you'll notice FF is a different forum from when you left. i stay in the local socal sub-forum because everywhere else is just about new owners asking if their wheels/tires will rub lol
Old Dec 16, 2010 | 01:32 PM
Goobers's Avatar
Can you say, combative?
Old Dec 16, 2010 | 01:44 PM
GD3_Wagoon's Avatar
...so i should stop helping others and instead troll threads like you? that's reasonable
Old Dec 16, 2010 | 02:00 PM
thefit09's Avatar
Maybe it's just me, but I wouldn't want help from someone as pretentious AND hypocritical as you, even if it is good information.
Sorry OP... back to thread.
Old Dec 16, 2010 | 02:22 PM
GD3_Wagoon's Avatar
next time i won't point a gun to your head and force you to read my posts. i'm sorry if i ruined your day, if it helps i take it all back. sleep well tonight, k? *HUGZZ-n-MUAHZ* xoxo...
you say, "back to the thread." as if you were ever invested in helping in the first place. the only thing you managed to contribute here was a personal attack. if you have an issue with me try a private message instead of derailing the thread.
Old Dec 16, 2010 | 05:16 PM
thefit09's Avatar
I just don't like hypocrites. You're all nice to someone's face and then you go tell your buddies how dumb they are for asking a question that you view as dumb or annoying. You know what? That's part of being on a forum like fitfreak. If you don't like it, take your own advice and stay on your own cozy little sub-forum.
I've never had a problem with you. I'm sure you're a nice, knowledgeable guy that can contribute to fitfreak. If you don't want to be called out for something, don't do it.
Old Dec 20, 2010 | 01:23 PM
circa40's Avatar
Thats all it took because he/she was the only person to give me any advice with nearly 100 views.
Thank you for your advice as well.
Just in case if anyone cares, i lowered the car and love the stance...its absolutely perfect IMO. With my previous cars, I had to go with coilovers to get the stance that I wanted (less then a finger gap).
However, there is some rubbing/scrapping when I drive over dips while driving ~35mph. There isnt any obvious scrape marks on my tires or outer fender lip. I will have to take off my tires to inspect the whole fender lining for damage when I have a chance.
bt08fit
Feb 13, 2012 06:40 PM
axe
15
Apr 19, 2010 09:54 AM
hiphapa
Jan 23, 2008 10:44 PM
Apex77
Nov 6, 2007 07:50 PM
abcsr2ez4me
Apr 30, 2007 07:19 PM
