Intake Problems. What should I do?
Old Dec 27, 2010 | 04:00 PM
Mr_Kunio's Avatar
So the other day I was going for an oil change when I noticed my car was choking and sputtering when I was at half throttle. The check engine came on so I looked under the hood.
Seems that the air filter for my Fujita sri popped off so I immediately put it back on and tightened it down. I drove away and the light went off but the car was still sputtering at low RPMs.
Unplugged the sensor and that looks good, and everything intake-wise is air tight.
What do you make of this Fit Freakers? Should I reset the ECU, Take apart the intake, or clean the filter or something? It seems the car isnt getting enough air or somthing like it cant breathe.
Thanks for reading!
Old Dec 28, 2010 | 12:41 AM
reako's Avatar
Just pull the negative battery cable off for a half-hour and put it back on. Should be good to go. **Be sure to have your radio security code on hand.
Old Dec 28, 2010 | 01:02 AM
Iamnotkento's Avatar
your radio security code is in your glove compartment. fyi
Arthur33
Jun 12, 2018 07:10 AM
hydesg
Apr 20, 2017 07:28 AM
jazzhands68
Dec 28, 2011 02:58 AM
slimchriz
Sep 25, 2009 08:44 PM
coldstorage5
Sep 1, 2006 01:33 AM
