is autotransmission ge8 strong enough?? PLEASE PRO TUNER REPLY
Old Jan 20, 2011 | 11:09 PM
ANGGGER's Avatar
is the automatic transmission of ge8 can handle upgraded L15A 250hp (1 bar) ?? is that the auto transmissin strong enough to handle that?
Old Jan 21, 2011 | 03:14 AM
mole177's Avatar
not a pro tuner...
but i believe the stock trans can handle 250hp, the question is how long....
250hp at the wheel or crank ?
either way, i'd be more worried of the internals.
Old Jan 21, 2011 | 03:23 AM
DiamondStarMonsters's Avatar
1 bar of boost can be 150whp on one compressor or 550whp on another so that is not a useful figure for your purposes.
You can run 250whp through your AT GE, but a big trans cooler core and fan will be necessary.
As well as constantly checking and changing your ATF.
A manual valve body, or a way to keep full line pressure on all shifts would go a long way to keeping your trans healthy too. It's the "slipping" in an AT that produces all the heat. Powerbraking is going to be a no-no as well.
Flashing or stalling up your stock converter will cause it to fail. But as long as you aren't constantly launching or anything you should be just fine.
New tougher clutches and frictions steels as well as a converter would be something to start researching as well.
Old Jan 21, 2011 | 04:52 AM
Lyon[Nightroad]'s Avatar
In my honest opinion, probably. But, if you're like me, you kind of want to do a tranny swap anyway. So why not throw the power at it, and see what happens. If it breaks, o well, time to shove in a junkyard manual.
I dont know how parts availability is over there, but even if I wanted to replace with another AT here I would pay:
2010
Transmission
Honda Fit1.5, AT900AAA0284$449Kinkers Auto Parts USA-OH(South-Webster) Request_Quote 877-614-1110 / 740-778-2659
I would focus on making the power first anyway. You guys in japan,indonesia, and taiwan actually have ge8s who have turbo's already though, this is good, seek them out.
Old Jan 21, 2011 | 08:52 PM
ANGGGER's Avatar
Originally Posted by mole177
not a pro tuner...
250hp on crank
my internals are low compression... with wiseco piston and crower rods.. and some fuel injector update and high flow fuel pump..
now u can answer the question about how long the trans can handle this?
Old Jan 21, 2011 | 09:15 PM
ANGGGER's Avatar
thank you dsm...
last year i've ask you about the pistons and the rods..
and i bought wiseco piston and crower rods..
here's the picture..
Crower Con-Rod with Wiseco Piston - OEM Con-Rod with OEM Piston
250 on crank... i'm so naif if i want 250hp on wheel..hehe
but if runs at 250hp on wheel the trans is still can handle?but how long?
i have installed atf cooler 7 rows..
the blue ones it's atf cooler..
"Flashing or stalling up your stock converter will cause it to fail. But as long as you aren't constantly launching or anything you should be just fine."
i don't understand can you explain more?
Old Jan 21, 2011 | 10:07 PM
ANGGGER's Avatar
2010
Transmission
thanks you for the link..
i've focused on the power first and now for the trans as well...haha
btw thank you for the link...
Old Jan 21, 2011 | 10:09 PM
ANGGGER's Avatar
2010
Transmission
my tuner say the trans is strong enough but some people misdoubt about this,,
Old Jan 21, 2011 | 10:47 PM
thank you dsm...
Glad I could help! Those rods/pistons should take anything you are looking to throw at them for now!
I hate to sound ignorant, but I would venture to guess it is often warm, even at night in Indonesia correct?
The big ATF cooler will help a lot, but to be safe if you have room, put a small slim fan on it, like 20cm diameter?
Also, good ATF fluid like AMSOIL or RedLine will help! Checking it and changing it often is going to be the key to longterm success!
Since you are turbo in hot climate think about a thicker engine oil, like 5w40 synthetic. This way it does not break down so fast, and deals with high heat from passing through the turbo!
When I talk about stalling up your converter... it is what some call "power braking" where some people put one foot on the brakes and the other on the gas and wait till they build boost and rpm, then they let go.
Doing this will wear things faster and breaks down trans fluid faster.
Heat is the enemy here, and what you can do to minimize it will help how long things last!
Your build looks very good man! Keep it up! Always excited to see a L15A build!
Old Jan 21, 2011 | 10:48 PM
2010
Transmission
I would +Rep you again but it won't let me lol
Old Jan 22, 2011 | 01:38 AM
ANGGGER's Avatar
yes i some places in indonesia is typically hot but i live in city of bandung, west java where the nite is quite cold in here..
i used honda oem ATF fluid...is it still able to help?
for engine oil i used blizt oil S3 20W50..
is it good enough?
oohh i understand what you mean about..."power braking" sometimes called "brake torquing" isn't?this will damage my trans a lot??
how about if i pull the gas on neutral gear then suddenly i swich to D gear it also break the trans?
This is awesome! I like the jdm front end so much better because you guys have much more room for routing the charge pipe. I don't think you'll find anyone who has yet applied that much power to the autotrans. You will just have to find out. Good luck! Make sure you let us know how it goes!
Old Jan 22, 2011 | 01:41 AM
I wish this car were like my t-bird and I could get a built high stall torque converter for dirt cheap. Looking at the service manual I don't think it will be so easy.
Old Jan 22, 2011 | 01:43 AM
how about if i pull the gas on neutral gear then suddenly i swich to D gear it also break the trans?[/QUOTE]
This is much much worse than brake torquing.
Old Jan 22, 2011 | 11:03 AM
ANGGGER's Avatar
hihihi... wish my luck bro,, i wanna find out the potential of matic car..hehe
many people underestimate matic car...
what is t-bird?
by the way your honda fit is auto or manual?
ohhhh why? it will spin the wheel and it's cool bro! hahaha,,
okay i never do that again..
Old Jan 23, 2011 | 01:27 PM
ANGGGER's Avatar
helllllllllooooooooooooooooooooooooooooooooooooooo o
Old Jan 24, 2011 | 08:03 AM
ANGGGER's Avatar
is it good enough?
Old Jan 24, 2011 | 08:19 AM
zymo's Avatar
What is cold to you? This morning it's -22C here.
Old Jan 24, 2011 | 12:09 PM
ANGGGER's Avatar
15C..LOLS..
wow -22C... damn good for turbo's haha..
Old Jan 24, 2011 | 12:30 PM
zymo's Avatar
15C..LOLS..
yeah - we barely need CAIs here. the air is already plenty cold
