Oil Life Monitor Increments of 10?
Old Jan 29, 2011 | 03:16 PM
LLLC1393's Avatar
I finally got to take a trip of some distance and have gotten the odometer to about 1400 miles now. I noticed that the oil life monitor went from 100% to 90 then 80. Is this the progression, or will it change as the numbers drop?
Old Jan 29, 2011 | 03:20 PM
naMtiF's Avatar
It counts down, never will go back up unless reset back to 100%
Clay
Old Jan 29, 2011 | 03:41 PM
LLLC1393's Avatar
Clay
Was referring to it going down by 10% at a time,as opposed to say 5% or some other odd number.
Old Jan 29, 2011 | 03:46 PM
naMtiF's Avatar
ahh, yes 10% increments is what I have always seen.
Old Jan 29, 2011 | 03:56 PM
GGPJON's Avatar
noob question: after an oil change, do you reset the oil monitor on the odo or does it do it by itself?
Old Jan 29, 2011 | 04:35 PM
Krimson_Cardnal's Avatar
It needs to be reset - procedure is in the owners manual.
Old Jan 29, 2011 | 05:16 PM
Goobers's Avatar
OH, the progression does change.
For most of it, it drops by 10. But when it gets to 30 (i think it was) percent, it changes to 5% drop till it hits ZERO.
How else would it hit 15%?
After that, it counts "up" into the negative numbers, but in miles instead.
Old Jan 29, 2011 | 08:19 PM
specboy's Avatar
I think it begins to drop by 5 once it hits 20. i've seen30 & 20 twice but never 25 after that it decreases by 5%.
~SB
Old Jan 29, 2011 | 10:07 PM
Goobers's Avatar
I wasn't sure if it was 20 or 30 (got my only oil change in Oct). I figured 20 was too close to the recommended 15%. c'est la vie.
spin out
Jun 13, 2016 06:55 PM
ncoflin
Mar 24, 2015 09:30 AM
Jensen Healy
Jun 2, 2010 12:26 AM
mole177
Feb 16, 2009 01:19 PM
tin
May 12, 2008 07:07 AM
