Bluetooth
Old Apr 14, 2011 | 01:03 PM
MetalMike's Avatar
Bluetooth
I don't know why i didn't think of this before, but does the 2011 fit with navi not have bluetooth? If so is there an after market option?
Old Apr 14, 2011 | 02:05 PM
BVictor's Avatar
I'm pretty sure that none of the Fit Navis have Bluetooth, not just the 2011.
Old Apr 14, 2011 | 02:09 PM
Coppatop85's Avatar
You need to replace your head unit / audio deck to get bluetooth. I got a nice double-din JVC that has bluetooth, and the sound quality is also ASTRONOMICALLY better.
Old Apr 14, 2011 | 05:00 PM
Goobers's Avatar
Uh, there are attachable bluetooth modules... notably the Parrot brand.
then there's this...
Old Apr 14, 2011 | 05:30 PM
TakeFlight's Avatar
I'm using this...
BlackBerry - Bluetooth Visor - Bluetooth Handsfree Speakerphone at BlackBerry.com
Works well and can also be used with the FM tuner and even displays the phone number via RDS. Since it transmits FM I use it with my Blackberry to listen to podcats and Pandora. Sound quality is on par with an average FM station. Good enough for a relatively inexpensive solution.
Old Feb 13, 2012 | 12:01 PM
DigitalDude65's Avatar
Where can i find one of these units?
Old Feb 13, 2012 | 10:23 PM
specboy's Avatar
I've had three different Bluetooth Setups in the FIT. the first was a Rechargable Parrot Minikit slim which I am now using with my blackberry (work phone). works fine while I'm on the road.
I also used my Garmin GPS with Bluetooth built in back before I had my Droid X2 as I primarily use the X2 for navigation now. The sound quality was good but every time i updated the Garmin, I had to re-pair the phone.(about 3-4x/year)
Now with the droid X2 in the Car, I use a belkin Bluetooth audio adapter:
http://www.amazon.com/Belkin-Bluetoo...9189322&sr=8-2
i leave the X2 in my pocket for my short drive to work and just hit the button. for longer drives, I drop the Droid in the Cradle to maintain the battery, use the GPS, and enable the audio(Streaming wireless to the aux input).
I find it convenient to use the belkin since my phone is my primary audio device in the car now (instead of usb)
I'd probably go Parrot hard-wire or double-din stereo if I spent more time in the car and used other devices for audio. I'm not in the car enough anymore to warrant it.
~SB
NotMyName
Aug 18, 2014 09:43 PM
polokid69
Oct 9, 2009 07:55 AM
GlennQuagmire
Jun 8, 2009 08:15 PM
robodude
Oct 10, 2008 10:32 PM
tstreete
Sep 24, 2008 11:21 PM
