HID help
Old Apr 14, 2011 | 05:15 PM
ej20i's Avatar
HID help
Hey guys,
got a H4 Hi/Lo HID fitted in GE, sometimes getting more and more now, only one side would turn on. but if you turn it off and back on the other side would work as well.
the side thats giving me problem is the non battery side..
any takers?
thanks
Old Apr 14, 2011 | 05:33 PM
Goobers's Avatar
are you using a relay?
try swapping the ballast from side to side. drive for a couple days to see if its the ballast. if nothing changed, swap the bulbs. check again.
if nothing changed there... it could be the wiring. if you're not using a relay, get one. if you already are... try to see if you can get a replacement
Old Apr 14, 2011 | 05:43 PM
sometimesjoe's Avatar
Is the other side grounded properly?
Old Apr 15, 2011 | 08:24 PM
ej20i's Avatar
yea its grounded properly, relay?im not any wiring diagram?
Old Apr 15, 2011 | 09:18 PM
Goobers's Avatar
The relay allows you to power both bulb straight from the battery, and it only plugs into one side of the OE headlight wiring (uses it as signal to turn on/high).
While you can make your own, some of the sellers offer a premade harness.
Old Apr 16, 2011 | 11:15 PM
halfmoonclip's Avatar
Tell me more about your lights; are they substitute bulbs or something more exotic?
I've used upwattage bulbs in H-4 housings for years, relays included.
Is this basically what you've done?
The less than stellar lights are one of my few complaints about the Fit.
Moon
Old Apr 17, 2011 | 10:31 PM
jrolon1's Avatar
What brand did you buy? Try out this if you don't have any luck.
Kaixen 5000K HID kit from Excelerate Performance.
http://www.excelerateperformance.com/
babybomb
Apr 14, 2011 11:50 PM
Turbo_Mouse
Feb 8, 2011 12:21 AM
kodo
19
Jan 24, 2009 12:49 PM
307890
Aug 5, 2008 10:03 PM
babybomb
Dec 29, 2007 04:52 AM
