Shifting troubles on a MT '10 Fit
Old Apr 15, 2011 | 07:37 AM
dramagrl248's Avatar
Shifting troubles on a AT '10 Fit
I have an automatic '10 Fit, 27,000 mi. Two weeks ago, I had my car serviced for a recall on the VTech system that had the potential to make my car stall out and not be able to restart. Since then, I have felt like my car was shifting more choppily and yesterday, when I got on the highway and accelerated to 60 mph, my transmission seemed to be stuck at 5 rpm, when it generally sits around 3 at that high speed. I was just wondering if anyone else had experienced problems like this before. Thanks.
Old Apr 15, 2011 | 08:34 AM
geomarathoner's Avatar
You were in 3rd gear instead of 5th.
Old Apr 15, 2011 | 08:53 AM
Schoat333's Avatar
Yep, that sounds like you were in 3rd gear.
If you were in fact in 5th gear, the only other explanation would be a slipping clutch.
Take it for a ride on the highway again, and check to see if it happens.
Old Apr 15, 2011 | 05:53 PM
I've always driven an automatic and I honestly don't know much about the different gears. But I do know that the rmp dial was at 5, not 2 or 3 like normal.
Old Apr 15, 2011 | 06:01 PM
know-nothin's Avatar
Not to be rude but if you don't know what gear you're in, it may time for an auto.
Goobers's Avatar
You've always driven an auto, but your topic title says your talking about a manual.
Did you just recently switch to a manual? Well, even if that were the case, if you made to third gear, you should've been able to just continue past it.
However, on the off chance you're still driving an auto, in "manual mode" AKA, S mode. The S mode will auto shift in the beginning (up to 3rd)... But leave the rest to you.
If you don't like that mode, stick to D mode.
Old Apr 15, 2011 | 07:11 PM
Sorry, thanks, fixed the details, don't know how that happened. I drive an automatic Fit.
m_x
72
Nov 16, 2018 04:10 PM
Fitftw15
Sep 1, 2017 07:45 AM
Raouf
May 28, 2014 07:16 PM
martymcfly
Oct 10, 2007 04:59 PM
Gordio
Jun 6, 2006 12:05 AM
