Clarification - there is no vtc on l series
Old May 23, 2011 | 05:47 PM
  #41
geomarathoner's Avatar
Geo, we were specifically talking about Honda's variable cam phasing system, which is what is often denoted by the i-VTEC moniker. Not Just Fit's in general.
And having a fixed advance on one lobe on a single cam is nothing like VTC, and in many instances will be detrimental to VE.
Yes, there were conversations about a number of ways to vary the valve timing...most of which are indeed different from the Fit's, and involve multiple cams and interesting cam drive sprockets. However, the Fit has the "i-VTEC" moniker on the cam cover and at a glance I saw a number of references to the Fit.
I owned a Taurus SHO for a long time.....made some interesting progress with cam and sprocket changes....what a beast from 4500-8500.
geo
Old May 23, 2011 | 09:32 PM
  #42
SilverBullet's Avatar
Originally Posted by blackndecker
I sure hope the "hot" CRZ that is rumored to be in the pipeline will have DOHC and be true i-VTEC...
Two words...head swap.
If thats true then you can see 150 HP plus even if you have to run 2 ecus. The DOHC cylinder head is where the powers at in a Honda. You can build a short block for less than a grand but not for a good head blueprinted with cams.
fittenmittens
Apr 16, 2017 08:40 PM
Koi
Nov 29, 2014 06:04 PM
stubuzz100
Feb 8, 2012 05:15 AM
cdnrsx
Feb 7, 2008 06:58 PM
Steve
Sep 12, 2005 09:30 AM
