Pic request: Painted rear "diffuser"
Old May 22, 2011 | 08:04 AM
solennel's Avatar
Per the title, I'm looking for pics of painted (other than OEM color) rear "diffusers," for the GE. (you know, that section of the rear bumper)
Additionally, as anyone painted the under side of their rear spoiler?
Old May 22, 2011 | 11:07 AM
britdevine's Avatar
Did mine in Plasti Dip so if I messed it up I could fix it easily, and also because it's totally removable. Has help up great so far for last month or so. Wheels alos plasti dip'd and holding up great.
Also did the front while I was it it with the Plasti dip
Old May 22, 2011 | 11:15 AM
solennel's Avatar
Thanks!
I assume you used the aerosol Plasti-Dip?
I've done a few parts on other cars, but I've found it comes off too easily, even with decent prepping.
Maybe I'll try vinyl?
Only contemplating, as some kind motorist nearly totalled my Taffy a few weeks ago, and it's getting a whole new front end - I was going to have the shop paint the rear while it's there.
We'll see, I'll either go semi permanent, or the full monty.
Old May 24, 2011 | 09:53 AM
britdevine's Avatar
Thanks!
Maybe you didnt use enough plasti-dip, I have 3 layers on the front and rear, and 4 layers on the wheels. Its help up great so far in very rainy and nasty weather for a month
Old May 24, 2011 | 11:50 AM
clownassasin's Avatar
Hey britdevine, did you do any prepping for the plastidip? or did you just spray it on
Old May 25, 2011 | 12:00 AM
britdevine's Avatar
Just cleaned the car good, taped off area ( the most important step), and sprayed. Just put on on thicker than you would spray paint, and do 3-4 layers.
Old May 30, 2011 | 10:34 PM
jnesselroad's Avatar
i just straight up painted it. i plan on driving this car into the ground (then maybe putting another engine in and doing it again)
Old Jun 1, 2011 | 02:06 PM
cfran55's Avatar
it wouldnt stay straight everytime i pulled of the tape. maybe i didnt let it dry enough or what?
Old Jun 1, 2011 | 03:36 PM
britdevine's Avatar
Was this plasti - dip.
You either have to let it dry completeley, and then carefully use exacto knife on it, or put on a 3-4 thick layers about 3-4 mins apart, and peel tape of while everything is still totally wet.
I did the wet version, and I have straight lines and it looks great.
Old Jun 1, 2011 | 03:43 PM
cfran55's Avatar
damn ill have to redo it then thanks for the tip!
Old Jun 3, 2011 | 07:44 PM
danlisahall@comcast.net's Avatar
Looks good, think I will do the same.
So are the perceived advantages to Plasti-dip vs good ol' Rustoleum or Krylon brand spray paints for the rear difuser?
Old Jun 3, 2011 | 07:53 PM
Plasti-dip is removable if I am correct, krylon fusion (what I used) chemically bonds to plastic, so it won't chip or flake, but no matter what, if you prep correctly, you'll be ok. Depends on the shine you want really. I think plasti-dip is pretty glossy. Mine went on semi-gloss, but dried almost satin.
Old Jun 3, 2011 | 08:44 PM
RetroAttack's Avatar
This is my rear diffuser
Old Jun 4, 2011 | 05:37 AM
Black3sr's Avatar
Old Jun 4, 2011 | 02:24 PM
SSMTEN's Avatar
how come the only people that ever paint the rear valence are TW drivers?? I have never seen another color with it done lol
liverpoolfcfan
20
Mar 26, 2012 07:39 PM
chunkylover8200
Jun 9, 2010 08:40 PM
heygotboost
Apr 5, 2009 05:29 PM
junior40er
44
Feb 27, 2009 05:45 PM
F'it_ImFromTx
Oct 15, 2008 02:34 PM
