Popping sound
Old Jun 11, 2011 | 05:46 PM
FitSSM2k10's Avatar
Popping sound
When i hut bumps at lower speeds I hear a popping noise. I've researched clunks/popped/grind and all sorts of other sounds. I honestly can't tell where it's coming from. I've checked all the suspension, looked for lose pieces, everything seems to be fine. I tightened everything again just to double check. Doesn't occur at higher speeds (that I can hear). Any thoughts?
Old Jun 11, 2011 | 06:15 PM
Goobers's Avatar
Is the Fit in your avatar, your car in question?
Check the fender lining for rubbing.
Old Jun 11, 2011 | 06:30 PM
FitSSM2k10's Avatar
No it's not the car in my avatar. Specs are in my signature. No signs of rubbing on the fender liners. I read somewhere that since I'm lowered it could be the sway bar tapping the axle or control arm, because the end links are too long.
Old Jun 11, 2011 | 07:10 PM
Goobers's Avatar
That would be more of a metal on metal "clank" than a pop.
Look at the endlinks that you think could be hitting the axle and look for signs of impact.
Though, I haven't seen such mention though.
Old Aug 12, 2013 | 08:59 PM
shortstop's Avatar
Ever figure it out? I damaged the original cv so I bought a new one when I lowered my car on t1r springs. I have loud popping sounds every so often usually when I turn left (on ramp, drive through)
Old Aug 12, 2013 | 09:12 PM
DavefromCA's Avatar
Spare tire and parts?
Old Aug 12, 2013 | 09:27 PM
shortstop's Avatar
Mine is definitely suspension related. I just double checked everything on the driver side and was able to turn the spring 1/2 to 1 inch (into the hole designed for spring to sit on) hoping I didnt have it set right will update. I have done suspension before but our fits are a lil funky compared to my odyssey and our older civics.
Old Aug 12, 2013 | 09:37 PM
shortstop's Avatar
Litle vibration at higher rpms, has to be cv related. going to check passenger tomorrow
howardmitch
Aug 4, 2017 08:02 PM
kreyzie
Nov 26, 2014 09:27 PM
jfw432
Sep 10, 2013 10:21 AM
willitfit
Oct 15, 2009 11:57 PM
808duece
May 13, 2009 04:10 AM
