2011 fit sport check engine light
Old Jul 5, 2011 | 09:50 AM
preludetofit's Avatar
I have a 2011 fit sport with 10k miles. The only mods are lowering springs and a twp throttle controller. This week my check engine light started to come on and the dash shows that it is the vehicle stability system. I was wondering if anyone else had this problem and if there is a service recall on it. I just keep resetting my ecu until I can get into Honda. Thanks for the answers.
Old Jul 5, 2011 | 10:04 AM
malraux's Avatar
Have you read the codes? If you are getting both the vsa light and the cel at the same time, my gut guess would be that you damaged a sensor or wire when you installed the springs.
Old Jul 5, 2011 | 10:07 AM
FIT-tles Worth's Avatar
^ would have to concur
Old Jul 5, 2011 | 10:22 AM
Krimson_Cardnal's Avatar
^^ditto on sensor wire^^ pull codes is the sure way - all else is guessing. Some auto supply stores will do it for free.
Old Jul 5, 2011 | 01:07 PM
Thanks for the replies. I didn't think I had done anything wrong when I installed the springs but it makes sense. Is this something I can fix myself as I'm sure I voided my warranty
Old Jul 5, 2011 | 02:16 PM
You've got to identify the problem before you can 'fix' it. Pulling codes will get you on track. You do know about the OBDII codes, don't you? I doubt you've voided the warranty.
Old Jul 5, 2011 | 02:25 PM
Here's something else, is the CEL flashing? then it's 'emissions' related. Have you checked the gas cap? A loose cap will trip the CEL. As well as the wire having been wacked there's a lot of other possibilities.
Old Jul 5, 2011 | 03:07 PM
Schoat333's Avatar
Have the code read to be sure.
My guess would be its the throttle controller causing it.
Old Jul 5, 2011 | 07:01 PM
It's a solid cel. I'm going to get the codes read when I stop working 12 hour shifts. I didn't think the controller would trip the vsa cel. This car is too new coming from a 97 prelude. I have lots to learn
Old Jul 5, 2011 | 07:33 PM
It's a pretty quick learning curve. I came off a 96 Sedan Deville. That CEL will tell you or a tech all you need to know.
Stacie Kahns
Sep 28, 2017 10:46 AM
pickmikey
Mar 24, 2014 02:41 PM
jmsplitfyre
Jan 7, 2013 03:41 AM
bjvalencia
Oct 11, 2011 03:16 AM
Velikimrav
Canada Fit Forums & Clubs
Apr 12, 2007 12:57 PM
