TEIN S TECH.....rubbbinnnn :/
Old Aug 23, 2011 | 10:59 PM
R..F..G's Avatar
Ive had these on my car for 3 months now, i like them but thinkin of switching them..even the small pot holes the driver side always seems to rub on the fender..i have to watch out for bumps everywhere in the road which SUCKS!
i was looking at eibach or swifts..any suggestions?????..i was thinkin about putting wheel spacers too..something so the wheels are flushed but arnt sticking out lookin crazy
but any suggestions would be nice im not too smart when it comes to this stuff
this is the front driver side
Old Aug 23, 2011 | 11:25 PM
SSMTEN's Avatar
im assuming you have aftermarket wheels on? i never rubbed once with my stechs on sport wheels, or my current wheels (16x7 +40). maybe you should just start dodging potholes lol.
Old Aug 24, 2011 | 05:06 AM
FIT-tles Worth's Avatar
size of wheels,tires,offset?
Old Aug 24, 2011 | 11:10 AM
mahout's Avatar
ill post some pictures of the drop later
The Teins are not likely the fault; its your choice of wheels offset. Any offset less than 45 mm is virtually assured of rubbing with any tire wider than 175.
The solution is not different springs but correct wheels and/or tires.
Old Aug 24, 2011 | 11:26 AM
GD3_Wagoon's Avatar
camber bolts ($20 on amazon) and an alignment is a cheaper fix than new springs. -1.5 camber is all it took to keep my front fenders from rubbing on 205/50/15 tires (15x7 +40 rims).
Old Aug 24, 2011 | 09:44 PM
R..F..G's Avatar
195/55/16, offset is 55mm im guessin
Old Aug 24, 2011 | 09:46 PM
R..F..G's Avatar
thanks for your input, when my tires are done ill get a better fitment if i still have the springs..
Old Aug 24, 2011 | 09:56 PM
SSMTEN's Avatar
HOW
Old Aug 25, 2011 | 01:16 PM
R..F..G's Avatar
Originally Posted by SSMTEN
HOW
haha dont know..i dont think im completly right with the offset, i just said that cus its the stock
but i think its my tires..they might be to big??
Old Aug 25, 2011 | 01:27 PM
Wanderer.'s Avatar
I would just do this.
It's probably just the tires and sidewall height. Those tires look super square.
Old Aug 25, 2011 | 02:10 PM
SSMTEN's Avatar
i suppose so. my stock dunlops were 185/55, so maybe that extra height is doing it.
Old Aug 25, 2011 | 04:35 PM
mahout's Avatar
195/55x16 tires are 24.45" diameter, stock is 185/55x16, and stock wheels are 52 mm offset. Your photos do not look like a wheel with 53 mm offset but they do look like stock. You using spacers? If so and more than 6 mm (1/4") thats your problem along with oversize tires.
The diameter of the tire is likely the fault unless the wheels aren't stock offset.
If you drop back to 195/50x16 you have a good chance of success.
Old Aug 25, 2011 | 07:51 PM
Bthasht's Avatar
Sounds to me like you are only rubbing inside fender liner on fronts. Check tires for cuts.
Old Aug 25, 2011 | 08:13 PM
Bthasht's Avatar
Old Aug 26, 2011 | 10:34 AM
SSMTEN's Avatar
True story. if it was the outside liner, you would see it chewed up a little in your second pic. if ANYTHING, a slightly lower offset (or spacer) would actually help you. Besides smaller tires that is..
Old Aug 26, 2011 | 11:39 AM
mahout's Avatar
Drop by your local speed shop and get a set of 1/4" spacers and install behind your wheels. That may be your easiest solution at a cost of $25-30.
Old Aug 27, 2011 | 04:27 PM
R..F..G's Avatar
Thanks for the feedback guys im gona try some camber bolts or spacers..because thats seems like the cheaper thing to do
eventually im going to get coils and take the springs off..but THANKSS AGAIN!
serinammavongsa
Feb 10, 2015 08:15 PM
Paulo107
Jul 22, 2014 10:07 AM
Fallen_Rock
Mar 26, 2012 06:57 AM
SoVa
Oct 6, 2011 12:08 AM
Rod2Rice
Jun 3, 2008 02:38 AM
