QUestion
Old Sep 7, 2011 | 12:27 PM
Pang3t's Avatar
QUestion
Hello im just wondering is it bad to drive without your tpms because i do have some other wheels that i like to put on and make my steelies for the winter(has the tpms) What are the consequences of have the tpms light go on?
Old Sep 7, 2011 | 12:48 PM
no issue. i do it all the time in the winter when running snow tire set without TPMS.
i currently dont run TPMS sensors in both my G or Z either as they have aftermarket wheels. i get the TPMS indicator but once i put my factory wheels back on it resets itself automatically.
Old Sep 7, 2011 | 01:12 PM
malraux's Avatar
The only disadvantage, beyond having to check your tire pressure, is that you cannot disable VSA while TPMS reports an error. And sometimes its useful to disable VSA to start moving on slick surfaces.
Old Sep 7, 2011 | 01:28 PM
Pang3t's Avatar
will it also effect the (idk wats its called but its ur car and it leaves tire marks) abs?
Old Sep 7, 2011 | 01:41 PM
malraux's Avatar
Anti-lock brakes will be on regardless. In theory, ABS prevents the tire marks.
Old Sep 7, 2011 | 01:48 PM
Pang3t's Avatar
Thank you but will it possible to also turn it off?
thank you everyone for the help saves me time and money
Old Sep 7, 2011 | 02:49 PM
malraux's Avatar
I presume you can pull the fuse, but really you shouldn't turn ABS off in the snow.
Old Sep 7, 2011 | 02:53 PM
Pang3t's Avatar
oh no i was thinking of my aftermarket ones without the tpms because at launch it stops my car -_-
my steelies are gna be winter wheels which have the tpms.
Old Sep 7, 2011 | 05:33 PM
Goobers's Avatar
that was the first thing malraux said: you can't disable VSA with the TPMS showing an error.
The VSA is actually the same module as the ABS, which is directly controlling your brakes (all of the brake lines run into the module, and then to the master brake cylinder).
Old Sep 7, 2011 | 07:39 PM
Pang3t's Avatar
Thank you.
Rampo
Feb 1, 2019 05:27 AM
jy1129
Jan 28, 2018 07:48 PM
Bogs2013
Jun 11, 2013 12:47 PM
Mini_Odyssey
Jan 9, 2013 02:46 AM
Bustov
Feb 25, 2009 01:40 PM
