Weird dome (overhead) light behavior
Old Sep 11, 2011 | 12:13 PM
Billburg's Avatar
Replace a burned out bulb in the dome light. The very same day, the thing starts acting erratic. When you open the door (with the switch set in the proper position), sometimes the light comes on and sometimes it doesn't. When it doesn't come on, moving the switch to "on" doesn't turn it on. Until it wants to.
I'm going to go out today when my wife gets home from church and spruce up the contacts, but any other ideas on this?
Thanks!
Joe
Old Sep 11, 2011 | 12:24 PM
Subie's Avatar
Reseat the bulb then recheck as you already planned on doing. Not much else left to do.
Old Sep 11, 2011 | 01:27 PM
Steve244's Avatar
new bulb could be bad.
The hot wire is constant on I believe, and ground is switched, either through a control unit or the switch on the dome light itself. If the new bulb isn't bad, the hot circuit must be interrupted at some point. Bad fuse (but not completely burned out)?
MonstaMatt
Feb 14, 2026 10:10 PM
Vash
Apr 2, 2014 12:10 PM
tonybabb
Dec 28, 2013 08:34 PM
amydan27
Jan 9, 2012 01:50 AM
kleinhanz.michael@gmail.com
Sep 21, 2005 08:31 AM
