Headlamps, so many, which ones to choose.
Old Dec 6, 2011 | 02:05 AM
  #41
Dazed's Avatar
Cipher them thangs is pretty bright haha. I was thinking about getting some projectors, but turns out I cant find any that come plug and play so i guess a retro fit will have to do....Also, if I wanted some LED tails, would those have to be modded as well to get on? or are there some out there that come plug and play?
Old Dec 6, 2011 | 02:23 AM
  #42
Jamy's Avatar
LED tails are plug and play. Check ebay for DEPO or look around for Axxis tails.
Old Dec 6, 2011 | 02:38 AM
  #43
Dazed's Avatar
Thanks bruh. Glad to know there is some shine of hope
Old Dec 6, 2011 | 05:21 AM
  #44
Cipher's Avatar
Those arent HID's or projector housings.
Just normal Fit housings with PIAA 2500k twin beam bulbs.
Most of PIAA's bulbs with the XTRA markings are very bright. Just pop em in and volah your good to go.
Old Dec 6, 2011 | 08:57 PM
  #45
lowkeymods's Avatar
Nokya Artic White is a great budget buy. Great color on the road and at a distance. Only issue I had was there was alot of the blue bulb reflection in the headlight up close.
Old Dec 15, 2011 | 05:50 AM
  #46
jm95286's Avatar
confused
Alright. So now I'm a lil confused. I was set on buying hids( these specifically) http://www.amazon.com/KENSUN-Xenon-Conversion-6000k-Crystal/dp/B001P1WRXG/ref=cm_cr_pr_product_top ...and now people are sayin halogens...I have around a hundred dollars and lookong for a clean lpok as well as visibility. Are the hids above crap? And a lot of friends have been sayin to go with ddm tuning hids....HELP
Old Dec 15, 2011 | 02:11 PM
  #47
Java^FiT's Avatar
Originally Posted by FittedOnEm
hid's in the fit headlights = big no no
that was with the low beams on only, and it still glared like a mother. i had them aimed all the way down and i could still see the top of trees. i ripped my kit out after the first night, stick with halogens unless you can afford to retro. from my research, philips is the halogen to go with for best visibility.
How the heck did you have that much glare with PnP's here are mine and I never ever get flashed at and they still light up plenty of the road! Eventually I am going to retrofit but I've been saving up for something much needed to the money being spent on the car is on hold.
Old Dec 15, 2011 | 03:04 PM
  #48
Jamy's Avatar
See java your glare isn't that bad but it's still two hot spots and wash out for the rest. Projectors don't give that. It's just a blanket of light. Good luck with your retro whenever you do it!
Old Dec 15, 2011 | 03:15 PM
  #49
Java^FiT's Avatar
Oh yeah i totally get its not dispersed like projectors would be which is why i want to do the retro, but ive been able to aim mine so the hot spots don't bother people...they illuminate the road which is the whole point hahaha i was just pointing out that not all kits glare the same way i guess
Old Dec 15, 2011 | 03:34 PM
  #50
Jamy's Avatar
Aye, Different kits/headlight housings will glare differently. Some more, some less than others.
Old Dec 15, 2011 | 06:14 PM
  #51
FittedOnEm's Avatar
Java, what kit do you have? I honestly blame it on the hidxtra kit I had since it didn't have a glare shield at all. I'm gonna try again with the DDM kit and we'll see how it goes. My civic didn't have any issues with it, and it used an H4 as well.
Old Dec 15, 2011 | 07:02 PM
  #52
Wanderer.'s Avatar
Cipher, if you're still following this thread, exactly how YELLOW is the low beam on those bulbs? Like really noticeable yellow or just a yellowish tint?
I'd like to get some better halogens and like the results you got, but here in California you'll get a ticket real quick for running yellow bulbs.
Old Dec 15, 2011 | 07:33 PM
  #53
Java^FiT's Avatar
I have all my kits from Top Speed Performance NY... Top Speed Performance
heres the thread that gets you the kits cheaper with a longer warranty
https://www.fitfreak.net/forums/fit-...-warranty.html
Old Dec 15, 2011 | 11:38 PM
  #54
lowkeymods's Avatar
Originally Posted by jm95286
Alright. So now I'm a lil confused. I was set on buying hids( these specifically) Amazon.com: KENSUN HID Xenon Conversion Kit 9006 (HB4)6000k (Crystal White): Automotive ...and now people are sayin halogens...I have around a hundred dollars and lookong for a clean lpok as well as visibility. Are the hids above crap? And a lot of friends have been sayin to go with ddm tuning hids....HELP
You need to use projectors w/ HID's which will cost at least $300. It doesn't matter how good or bad of quality HID kit you get w/o projectors because the light will go everywhere anyway, including other driver's eyes. I say go w/ PIAA or Nokya for now and save up for a retrofit.
Old Dec 16, 2011 | 10:44 AM
  #55
wetphoto's Avatar
I did HID conversion to another car of mine. Bad idea. I switched to Sylvania Silverstar Ultras. Cheap and really good.
Old Dec 22, 2011 | 04:26 AM
  #56
Cipher's Avatar
Hey hopefully you see this!
I dont know about the US but in Canada we run a DRL (Daytime running light) and the DRL's on the PIAA is a bit yellow/green.
The low beams looking at the car are pretty white. There is some yellow/green but it isnt very noticeable. What you do notice is how yellow/green the light in front of the car is on the low beams.
Here's a shitty FB picture of the low beams. Now I AM at a very low angle to try and catch the green/yellow on my phone camera. Any higher then headlight level and its mostly white.
Great bulbs. I know where I live you need to have "white" headlights and I haven't gotten a ticket yet.
My room mate in his 240 got a ticket after 3 days with his yellow HID's and I've been fine for just about 2 months now. Hell I was even pulled over the other night after driving home from the bar and the officer didnt care.
Old Dec 22, 2011 | 10:26 AM
  #57
Wanderer.'s Avatar
^That looks completely passable.
Just in time for the holidays, I guess I know what i'm doing with my christmas money lol
Thanks a bunch!
derykisonder
Sep 9, 2015 01:50 AM
boricuawarior
Apr 14, 2012 03:40 PM
jazz_do_it
Jul 19, 2008 04:09 PM
cheebz
Oct 16, 2007 10:40 PM
Luichenwai
28
Jul 18, 2007 03:40 PM
