Horn Upgrade for 2012 slightly different
Old Jun 13, 2012 | 01:32 AM
  #41
msbxiv's Avatar
Originally Posted by fujisawa
Improvement on volume? The stock horn is, well, I'll put it this way: When I hit the horn button I hear a faint noise from somewhere far away and I go "that can't possibly be it, did I miss the button?" ... But I didn't.
It's more noticeable and less comical. It's just the low note, but I think it's better than the meep meep horn.
2009 Honda Fit with '08 Accord Horn - YouTube
Old Oct 5, 2012 | 01:28 PM
  #42
tedmondsjr's Avatar
Thanks to the OP and MSBXIV for their information in this thread. Just installed an Accord horn (backwards per MSBXIV's suggestion) and it's working perfectly.
Old Jan 30, 2013 | 03:26 PM
  #43
SF Fit's Avatar
Any special installations needed to install PIAA?
Originally Posted by tr4boy
Had the same problem with my '12. Thought I could just loosen the screw on back and move the bracket around. That didn't really work though because the best position I found stretched the lead and had the horn pointing up. I ended up making a bracket out of aluminum that dropped the accord horn down and to the right (from the front of the car). Took the tension off the lead and got the horn pointed down. Took about an hour.
The bad news is that while the Accord horn (low) is much better than stock, it's still not all that great. I will be putting in PIAA horns (500hz and 600hz) once they get here. Also, since I'm not a fan of modifying the wiring harness, I cut the connector off the stock horn an soldered a lead to it. Now I can connect into the stock harness without cutting it. The end of the lead will go into the relay which will be wired as normal
hi tr4boy, i want to upgrade to a PIAA horn and wanted to know if you could tell me if i can use just about any of them or was there a reason why you chose the 500/600.
any help on how to install a PIAA horn and info on alterations that need to be made would be super helpful.
Old Jan 31, 2013 | 10:15 PM
  #44
tr4boy's Avatar
SF Fit,
I have 500/600 pair on my '64 triumph tr-4 and like the tone. Seemed like a good fit for the Fit...
Installation is dead easy...just follow the diagram...really simple.
Old Feb 4, 2013 | 02:17 PM
  #45
SF Fit's Avatar
thx
i like simple! when you say pair are you saying you installed 2 of them or just that it contains the 2 different frequencies?
Old Feb 4, 2013 | 10:39 PM
  #46
tr4boy's Avatar
yeah, they're a pair...a 500 and 600...
Greengo
Apr 9, 2012 04:49 PM
SevereService
Feb 2, 2012 08:23 AM
The Assassin
Aug 22, 2010 09:52 PM
FLEALAMI
Jan 23, 2010 03:57 PM
gummyrabbit
Nov 23, 2007 03:30 PM
