taller tire 195x65x15 clearance?
Old Jan 13, 2012 | 10:36 AM
tim2972's Avatar
I have an 09 Fit Sport.
Has anyone put a 1 inch larger diameter tire on their Fit?
To improve ride comfort I want to buy 15 inch rims and
use 195x65x15 tires.
Will there be any clearance issues when turning the steering wheel?
I know my speedo and odometer will be off a bit but that is okay.
Tire rack says stock 185x55x16 is 24 inch diameter. The 195x65x15 would be 25 inch diameter.
Michigan has very rough roads so that is why I do not want the 55 or 60 profile tires.
The rim I want to get is 15x7, so with the width they suggest a 195 over a 185 width tire.
Thanks
tim2972
Old Jan 13, 2012 | 11:17 AM
Wanderer.'s Avatar
Thanks
tim2972
It's going to depend more on the wheel offset than the tire if you're at stock height. If you keep the offset around +40mm you should be fine.
I run 185/65/15 on stock steel wheels with lowered suspension and I have no problems.
Old Jan 13, 2012 | 08:54 PM
specboy's Avatar
I'm running the same size wheel/tire combo for my winters... however, i'm not lowered. That puts us about 1/4" +/- higher off the ground. OP, you should have no issues if you aren't lowered. Remember though, your odometer and speedo will be off by a bit so make sure you adjust your speed when driving to avoid tickets. you'll be somewhere around 3mph(iirc) higher than what your speedo says at 60mph.
~SB
utsug
Feb 17, 2017 09:44 PM
Splater
Mar 15, 2013 12:51 AM
thewwkayaker
Oct 19, 2012 10:43 PM
d_2
Nov 19, 2011 06:51 PM
wpgfit
Jul 3, 2007 12:53 AM
