MT: light to tell you to shift gears
Old Jan 17, 2012 | 06:42 PM
fstyle751's Avatar
Does the Fit have the light on the dashboard that tells you when to shift gears in the MT?
Old Jan 17, 2012 | 06:58 PM
Hondafrk's Avatar
No, that's what a tach is for.
Old Jan 17, 2012 | 07:04 PM
Jamy's Avatar
Nope. Use the tach and shift at 4k and you should be fine.
Old Jan 17, 2012 | 07:11 PM
micven55's Avatar
I had one on my VW and it would come on as soon as the RPM got over 2500. Very annoying and the bulb was removed quickly.
Old Jan 17, 2012 | 07:14 PM
555sexydrive's Avatar
That is what your ears are for. Do people really look at a tachometer before they shift?
Old Jan 17, 2012 | 07:16 PM
Jamy's Avatar
When I switch car I do at first till I learn how the engine sounds and what to expect. I don't look anymore unless I'm really trying to wind it out as far as it will go though.
Old Jan 17, 2012 | 07:25 PM
fstyle751's Avatar
4000 rpm. Thanks!
Old Jan 17, 2012 | 07:27 PM
Understand Jamy. I've only owned Hondas and they have all liked to rev, well the Fit somewhat does. I don't think I have ever once used my tach in any vehicle, well not true, I used it to see where it idled at and where it sat upon startup.
Old Jan 17, 2012 | 07:34 PM
Hondafrk's Avatar
4000 rpm. Thanks!
You don't have to shift there just fyi.
Old Jan 17, 2012 | 07:43 PM
Jamy's Avatar
4000 rpm. Thanks!
What He said^ that's just where I like to shift.
Ah see I've had a BMW, a Jeep, an Infiniti, and this is my first honda so it took getting used to. Now I laugh when I see friends shifting at 5k or so cause it "runs out of power". I've gotten used to the "vtec yo, wind that shit out!" effect.
Old Jan 17, 2012 | 07:57 PM
Steve244's Avatar
I had one of those too. hated it. I think it came on at some manifold vacuum indicating the most efficient time to shift (not the highest safe rpm). I rarely followed it.
But it does bring up the OP's question of when to shift. There is no correct RPM at which to shift. It's a function of how fast you want to accelerate and how much you want to save fuel (without lugging the engine). It depends more on your mood than anything else.
Old Jan 17, 2012 | 07:59 PM
Jamy's Avatar
The Manual has the recommended shift point speed wise. Not by RPM. I forget what they are though and too tired to go find mine to look it up.
Old Jan 17, 2012 | 08:32 PM
I shift at like 2500-3000 rpm lulz
Old Jan 17, 2012 | 08:55 PM
YouKantPimpInaKIA's Avatar
I thought that's what the Rev Limiter was used for?
Old Jan 17, 2012 | 08:56 PM
Goobers's Avatar
I think the speed correspond to roughly 3000 rpm. The one speed I do remember is from 4th to 5th gear, @44mph. 44mph is close to 3000rpm in 4th.
Old Jan 17, 2012 | 09:27 PM
Wanderer.'s Avatar
I came here to post this
Old Jan 17, 2012 | 09:43 PM
atokin's Avatar
my Si had a built in shiftlight that would start bothering me at 7600 rpm
Old Jan 17, 2012 | 10:47 PM
afreespirit's Avatar
My 2012 Fit Manual lists the following shift speeds (for MT):
1st to 2nd--15mph
2nd to 3rd--27mph
3rd to 4th--39mph
4th to 5th--53mph
Old Jan 17, 2012 | 10:51 PM
Mine are something like this:
1-2 = 5-10 mph
2-3 = 20ish mph
3-4 = 35ish mph
4-5 = 40-45 mph
Old Jan 17, 2012 | 11:43 PM
kaphinga's Avatar
Does anyone know why the manual says to shift at these speeds? I usually shift at lower speeds, similar to what mike410b says, unless I am going up a hill.
1st to 2nd--15mph
2nd to 3rd--27mph
3rd to 4th--39mph
4th to 5th--53mph
