License Plate Bolt Size ?
Old Jan 29, 2012 | 03:28 PM
schwimmair's Avatar
The yahoos at the dealership cross threaded the license plate bolts and I discovered the bolts will on go in half way.
I bought the car used and it included a 1 month warranty which of course when I got my permanent plate a month later the warranty ran its course.
Does anybody know the correct bolt/screw to use? I'm doubting the ones I have are even the correct size.
I would hate to have to get the bolt hole re-tapped so I am hoping someone might know which type of bolt to buy. I am assuming it is a metric but not sure of the diameter and the thread pitch or count.
As for the dealer, this is the second car I bought from them and probably the last. If they are too lazy to get the corrects bolts, I am sure they are slacking on the "125 point inspection" as well.
Thanks,
Schwimm
Old Jan 29, 2012 | 04:24 PM
mahout's Avatar
Thanks,
Schwimm
Half way? How far is that? And did they snug up to th temp plate?. Do the temp bolts have a shoulder instead of full thread? And how come the dealer won't supply you with the correct bolt? They ought to have bags of them. Use a matching hex head of matching threads to tap the threads
to the original.
Old Jan 29, 2012 | 09:44 PM
schwimmair's Avatar
to the original.
mahout, thanks for the help. As for the dealer it was Carmax not a Honda dealer but you would think they would see enough Honda's to know which type to install.
After researching I found out cars use 2 type of license plate screws/bolts.
Some use a standard screw which looks more like a screw. The threads on these are spaced wider apart and has a pointy end.
Others use metric screws which looks more like a bolt. The threads are spaced closer and the end is flat.
I am guessing only U.S. manufacturers use standard screws, as the rest of the world is on the metric system.
Carmax used a standard screw on my Fit but luckily didn't do any damage as I could hand tighten the metric bolts all the way into the hole with ease.
I am doubting this will be hopeful to anyone but the metric bolt size in a M6 (6mm) and was 20mm long.
I got my bolts from Home Depot. They are Crown Bolt brand and that package says:
Flange Bolts
M6-1.0 x 20mm
Zinc Plated
The SKU is 030699363988.
I am guessing this is a universal size so I am sure a zillion places has this size.
Schwimm
Old May 30, 2013 | 08:24 AM
curtishartling's Avatar
Flange Bolts
M6-1.0 x 20mm
Zinc Plated
Schwimm
Thank you very much for posting this information. This is the exact issue I have! I'm headed to the Home Depot this afternoon for the quick fix. Thanks again!
- Curtis
Old May 30, 2013 | 11:49 AM
Jamieson's Avatar
I just bought some stainless bolts and screws for the license plates. Rear license plate is M6 x 15 or 20mm. The front license plate is held in with what looks like wood screws. These are probably metric, but the closest I could find at my local hardware store is #14 x 1/2".
bwolf65
Jan 18, 2015 01:47 AM
madtodaimax
May 13, 2014 02:35 PM
Raouf
Sep 26, 2010 05:16 PM
jrstinkfish
May 26, 2007 11:18 PM
Brooklin
Jun 3, 2005 01:06 AM
