Speaker upgrades? Worth it?
Old Feb 14, 2012 | 10:33 AM
Fit4Spl's Avatar
Originally Posted by ShadowMoses
I should clarify, but I assure you, it does not defy physics. Say your speakers are rated at 120w and your head unit can push 50w. The speaker can handle all the power of the head unit, but when you crank the output to the head unit's maximum you run into clipping. The head unit will try and accommodate and send the increased power to the speaker, but it be sending distortion. This, I promise you, will ruin your speakers.
Sorry a head unit rated at 50watts per channel will only put out 50watts of power per channel at the rated ohm load. The distortion or clipped signal is not more power, it's a dirty signal they are not the same thing. And as I said in my previous to this reply, yes distortion will destroy a speaker, however it usually takes a period of time. Unless you are talking someone hardcore like a dB Drag competitor who is throwing 1000's of watts at a sub for a burst period of time, in which that signal with distortion can destroy a speaker in mere seconds.
ThEvil0nE's Avatar
back to topic... if anyone wants a serious audiophile component system that'll blow your mind without blowing your pocket then look no further Autosound Speaker Kits for the Car I know it's a 6.5 and needs work to make it fit. Madisound is a DIY audiophile store.
Old Feb 14, 2012 | 10:36 AM
x_25's Avatar
Originally Posted by Fit4Spl
If the person installing the speakers and amp knows their product and theory the amp should be set properly with either a portable o-scope, DMM or a new product I picked up by Steve Meade, the DD-1. In this fashion the amp can be set along with the head unit to it's maximum potential without clipping. Example, I use the DD-1 to measure the head unit completely flat eq and Xover settings. I get the result of 25 out of 30 volume for max undistorted (clipped) signal from the head unit. I then test the amp in the same fashion, eq flat and xovers wide open. After adjusting the gain right below the clipping point, this will allow the user to play his system at 25 (max undistorted/clipped signal) and get the most out of his/her amp.
However most audio shops, mass stores (best buy etc) do not employ this type of philosophy which is sad because it takes 10mins to complete after you learn this method with the DD-1. So most people who get something installed at a shop or mass store will have no clue where anything is set and most of them will at some point end up sending distorted/clipped signal to their speakers. However even a clipped signal at low power will not destroy a speaker quickly it will depend on how much the user does it, and how often.
So while what you are saying is technically correct, if we go by pure physics which does not account for a distorted signal, a under powered speaker will not blow. A uneducated user with a itchy volume finger who likes to crank his system beyond it's limits with badly set gains on amps could possibly do it, however it would take time.
Yep. Exactly. I don't run my headunit past 15, since much above that I can start to hear some distortion (no amp, just running off the head unit). Though that is with recordings that run right to digital zero. Quieter ones I will crank it up a bit more.
The number of people who run their system into distortion "because it sounds better and louder" will supprise you. There are a lot of idiots out there, sadly.
The other issue is the average joe now seems to want boom and sizzle, midrange be damned. And the speaker companies are catering. I am having trouble finding speakers that don't make my ears bleed and will fit in my car.
Old Feb 14, 2012 | 10:37 AM
Fit4Spl's Avatar
Parts Express: the #1 source for audio, video & speaker building components is another great place to build your own components, I saw a Focal midrange/midbass driver on there last week for like $8 per driver. That's INSANE cheap!
Old Feb 14, 2012 | 10:39 AM
ThEvil0nE's Avatar
love their buyout specials... I get their circulars in the mail regularly
Old Feb 14, 2012 | 10:41 AM
x_25's Avatar
Never would have thought to check madisound. Will definetly take a look. I have been searching parts express though.
Old Feb 14, 2012 | 10:57 AM
ThEvil0nE's Avatar
This discussion has officially gone over my head. Officially.
I was keeping it as palatable as possible but you know how it is in FF
As for your headunit needs... look into Alpine and Kenwood (these are just my preference). Get a unit that is flexible and expandable, what this relates to is you will have the option to add amps and have yourself a full dedicated system in the future
Old Feb 14, 2012 | 11:29 AM
ShadowMoses's Avatar
I'll just leave this here:
http://en.wikipedia.org/wiki/Clipping_(audio)
Note the Effects of Clipping section showing the sine wave of a clipped signal, with more area under the curve, therefore producing more power. Weird. Most people who are proficient in an area forget that not everyone is like that. Things all sound great in "theory," but in practice they often end up differently. People crank their stereos into clipping and ruin speakers. It happens. Of course if everyone used a DD-1 and understood exactly how everything works then none of this would happen, but not everyone does.
Old Feb 14, 2012 | 12:24 PM
bike_fit_B's Avatar
Nice, thanks guys. I'll have to do my homework. All this info is very helpful. One thing i will say right now is that unless i can very inconspicuously hide an amp i don't want to add one. As i think i mentioned i'm not really looking for an extremely bass heavy sound, more a full sound with clear tone. I was able to achieve this in my accord with a jbl 6 x9's and a pioneer deck, no amps or anything other. I have plenty of experience with audio live sound, not car audio) so i'm not particularly worried about blowing speakers. i know i can figure it out if i look, but seeing as i'm lazy and working anybody know what the stock speakers are rated for?
Old Feb 14, 2012 | 12:28 PM
x_25's Avatar
Not sure the rateing for the stock speakers, but as far as hideing the amp I am going to be building an new spair tire cover ahdn hanging the amp from the bottom of that into the tire. I though of it one day at work and was pleased to find somone (forget the name) on thos forum who did it with an Alpine PDX-5. It has to be a small amp though. I need to take some measurements but I am hopeing the Alpine MRX-V60 will fit as well.
Old Feb 14, 2012 | 02:59 PM
raytseng's Avatar
Lot of car audio enthusiasts have spoken already, there's a whole I.C.E subforum btw, so obviously many people feel it is plenty "worth it" to put down their dollars.
My 2cents, unless you are also going to spend a LOT to reduce the road noise in the FiT, I don't think it's worth it to spend money on just the speakers. Then you're putting in a significant amount of effort and investment to make a big project. If it were a much quieter cabin out of the factory, I might have a different opinion.
Unless you use the FiT for mobile audio, where you are sitting around parked enjoying your tunes.
I personally use this car just as a vehicle to get me where I want to go or carry a bunch of stuff. Once I'm there, my priority is to go about my business rather than music. I can listen to tunes at home on a more "real" sound system.
Old Feb 14, 2012 | 03:27 PM
  #32
bike_fit_B's Avatar
While i don't completely disagree with you, there is something to be said for being able to enjoy some subtleties of the music you enjoy while on the road. And i do a lot of driving, mostly at low(er) speeds, back roads and city streets etc... I'm just looking for an economical way to unobtrusively enhance whats there. I don't think i have the patience, and i definitely don't have to money to completely overhaul what's there right now anyway (Plus the car is 1 week new to me; way too soon to think about serious upgrades!).
Old Feb 14, 2012 | 09:00 PM
  #33
komafit's Avatar
Originally Posted by x_25
And for anyone with a 2012 fit, honda has stopped painting the radio bezel and upper glove box that ugly silver color, so a lot of the aftermarket instal kits won't match for color. You will need to check into it.
Only in the 2012 Sports are they darker, the Bases are still silver or what they call "NEUTRAL MAT GUN METALLIC."
I'm not really understanding this but the price on the bezel alone is $423, not including the actual headunit. So if anyone is looking to get rid of that bezel, I'd take it off your hands (for a more reasonable cost)
Old Feb 14, 2012 | 09:07 PM
  #34
x_25's Avatar
The stock bezel that comes from the factory? Heck, I'd sell you the stock head unit with iPod interface and the silver bezel for half that.
It's never too soon for serious upgrades. I had half my interior apart in the first 300 miles.
Old Feb 14, 2012 | 09:54 PM
  #35
Eugene.Atget's Avatar
Just bought a 2012 Fit Sport a/t w/o nav. I like the ipod interface on the stock stereo but find the low end to be a little lacking. Being somewhat of an audiophile first though would be to upgrade from paper cones. Anybody out there upgrade just the speakers and run the stock deck? I'm to hold off for a least a year before i start making serious upgrades...
I replaced the front speakers on my 2009 Sport first, then the HU, then the rear speakers. The speakers are Polk Audio db651, and the HU is a JVC Arsenal KD-A815 (discontinued, I believe). Replacing just the front speakers made a large difference in sound, but I still wasn’t satisfied and so I then replaced the HU. That resulted in another large difference in sound, especially stereo imaging. While I had the Polks in the front and the OEM speakers still in the rear I used the fader to switch back and forth–the rears made the soprano sound as though she was singing over the telephone in comparison to the Polks. All-in-all I’d say that 60% of the harsh, fatiguing sound that imo comes from the OEM system is due to the speakers, and the remaining 40% from the HU. So, yes, it’s worth it just to replace the speakers, but my guess is that you’ll end up replacing the whole system in the end (that said, I simply left the stock tweeters and all the wiring in place).
Raytseng makes a good point above, that you'll always be fighting with road noise, unless perhaps you purchased the new CE, which apparently comes with some soundproofing.
Old Feb 14, 2012 | 10:16 PM
  #36
lowkeymods's Avatar
If you're looking for low end I would replace the deck first. My Polk's have great highs/mids but don't have the low end that the stockers did, hence the sub.
Old Mar 21, 2012 | 08:15 PM
  #37
Dawsona2's Avatar
Hi lowkeymods,
what wheel/tires are you running in your pic?
They look great!
Thanks!
We have a blue Fit so would prob get the silver wheels if they got 'em...don't want to exactly copy
Old Mar 21, 2012 | 08:25 PM
  #38
lowkeymods's Avatar
Thanks! Konig Feathers 17x7 w/ Yokahama S-Drives 195/45/17 lowered on Swifts. I think gold would look pretty frickin sick on blue...go ahead and copy, lord knows I did...
Old Mar 21, 2012 | 08:44 PM
  #39
Dawsona2's Avatar
lol good point....so the car is lowered on swift spings?
I am a three say old Fit owner BTW, getting started in all this
The blue on gold is nice, gold on black is sweet tho.
What lens cover you got on your fogs? I heard the yellow is better for snow driving...
cheers!
Old Mar 21, 2012 | 08:47 PM
  #40
Dawsona2's Avatar
oh yeah, I originally meant to ask...any issues with offset or do they need spacers or anything?
and I will be messing with my locking gas cap tonight/tomorrow...see if I can get anything to work
