Automatic shifting quality
Old Mar 30, 2012 | 10:22 PM
ltd's Avatar
ltd
I had 2012 Fit base Auto, From 1 to 2 the transmission does not shifted smoothly as like 3,4,5. Is this normal for this tranny ?
Old Mar 31, 2012 | 06:18 AM
matt1357's Avatar
Mine is like this also. I don't think its so much that 1st to 2nd is different in the gearing than 2nd to 3rd. Its just such a light car that you get a little lurch when it shifts because your going at slow speeds during that shift. The other shifts the car has more momentum so you don't feel it. I think if you put 3 adults in the car with you it will shift smoother because of the extra weight.
Ive had other light automatics that feel the same, nothing to worry about.
Old Mar 31, 2012 | 07:36 AM
ltd's Avatar
ltd
I fell safe now after your infos Matt1357. Thanks.
Old Mar 31, 2012 | 01:15 PM
boyFIT11's Avatar
Mine shifts 2nd to 3rd at 4,500rpm
Old Mar 31, 2012 | 02:14 PM
matt1357's Avatar
that could be an issue...mine will shift anywhere between 2 and redline depending on how hard Im on the throttle. My only annoyance with this transmission is when Im slowing for a stopsign or light and come to 1-5mph then give it gas to take off again it downshifts to first rather abruptly and lurches the car...its worse while the transmission is cold. it would not do this if the car was a 4speed because it would already be in first by that speed. The lighter you throttle it the less it will do it but it still annoys the crap outta me.
Old Mar 31, 2012 | 07:24 PM
raytseng's Avatar
First thing you should try is just do a drain/fill with new transmission fluid.
If you DIY it's not expensive and has a good chance of helping things. If it doesn't, you're not out a whole lot...
Old Mar 31, 2012 | 08:06 PM
malraux's Avatar
If its a 2012, it has the correct fluid.
Old Mar 31, 2012 | 08:19 PM
raytseng's Avatar
Doesn't matter if it already has dw-1. From all the trans oil change DIYs, notice there's a decent amount of deposits from the break-in.
Just doing a change at least once can potentially help, or at least rule that out as the cause.
The only downside is just cost of fluid (relatively small) if you're a capable DIYer, whereas there's potentially large upside.
Old Apr 1, 2012 | 01:35 AM
Shockwave199's Avatar
The simple solution is, don't let the Fit drive you. YOU drive the Fit. It loves to be driven. It's excited when you give it the gas. It's made to perform. Don't be a wimpy accelerator for the sake of squeezing an 1/8th of a gallon more. I don't mean stomp on it or jack rabbit. But push it through the gears with some authority- it loves it and so will you.
Old Apr 2, 2012 | 03:05 AM
BraytonAK's Avatar
Thumbs down
Exactly! I hate that stupid rolling stop jump. Makes it difficult to take off when you really need to without feeling like you're going to shred the transmission.
Old Jun 5, 2012 | 10:15 AM
c.s.'s Avatar
Appreciate the info here. I was wondering why my Fit felt "jumpy" - I've owned a Civc, Accord, and Odyssey, and none of them felt this way. When I really step on it, it shifts a lot smoother. I just hope the transmission will be okay long-term.
Old Jun 5, 2012 | 11:34 AM
adolan21's Avatar
It's interesting that the 1-2 shift is rough on the autos as its the tougher shift on the manuals as well.
Old Jun 8, 2012 | 12:12 AM
neozengar's Avatar
I also notice the same thing on my 2012 base fit. I found that if I give more gas as I accelerate, I did not feel the jerkiness. I am not sure if that will hurt my MPG though.
Old Jun 8, 2012 | 07:48 PM
zilla8's Avatar
I think this is the thrid thread I've seen concerning the A/T.
I have a 2012 Sport and have none of these issues.This transmission is actually one of the best I've seen in many years.
It's as if I can control everything with my throttle input.It shifts so smooth it feels like a CVT
I take full advantage of this transmission including using the paddles in D as well as sport mode.
What some of you are experiencing is the total oppisite of what I'm seeing.
I wish I had a answer but I just cannot think of anything.
geneironlungs
Oct 5, 2014 03:27 AM
The Critic
May 21, 2011 08:47 PM
MT5_Fit
Aug 10, 2008 02:06 PM
zukered
Aug 4, 2008 05:59 PM
fitinfit
Jul 20, 2007 01:25 PM
