Jack under rear springs?
Old Apr 22, 2012 | 09:27 PM
Rook's Avatar
Can I safely use my trolly jack under the rear springs? Seems like a nice big flat area to lift the rear tires with
Old Apr 22, 2012 | 09:50 PM
Goobers's Avatar
You can try, but its not really all that useful since most of your effort will be spent compressing the spring into the car. As long as you have a rubberized pad on the jack, you can just use the normal jacking position between the wheels.
If you have a long enough floor jack, you can raise the entire rear end by using the center position (under the spare tire area). Then slide a pair of jack stands at the jacking spots by the wheels.
Old Apr 22, 2012 | 10:05 PM
Potenza's Avatar
No, that is not a safe jacking point. Use the correct factory specified jack points on the car.
Old Apr 23, 2012 | 09:42 PM
Rook's Avatar
The springs are already compressed from the wieght of the car. Useing this point is fast because it lifts the car immediatly instead of spending the effort decompressing the springs away from the car when you use the standard point. I just wasn't sure about the integrity of the spring mounts. I thought since the down force was on them already that they would handle the reverse.
Old Apr 23, 2012 | 11:36 PM
JAZZdatFIT's Avatar
like the others said, jacking up at the spring points are kind of useless lol. goobers idea is solid. jack in right in between, will be a silver square spot to use as jack point. thats where i jacked my rear up when installing my coils
Old Apr 24, 2012 | 12:47 AM
Goobers's Avatar
no... as you lift the jack, the weight of the car shifts, eventually, that jacked spring and the opposite corner are supporting more and more of the weight.
As there's more weight putting pressure, the spring compresses.
It's only fast, if your intention is to take off the wheel.
Old Apr 24, 2012 | 03:34 AM
kgb4187's Avatar
No... No... What do you think happens to the spring when you go over a bump? I think jacking it would cause them to be under a dangerous amount of stress, if the jack is uneven it would probably shoot out and drop the car down. Why wouldn't you spend a few extra seconds to jack the car properly?
Old Apr 25, 2012 | 02:46 AM
Potenza's Avatar
It's not safe, just don't do it, period. No need to even argue the point.
Your eagerness to save 30 seconds of jack time could cost you an arm or a leg... literally.
Honda specified the correct jack points, USE THEM!
Erikdag
30
Dec 1, 2020 08:40 PM
dstahnke
May 3, 2012 10:14 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
dewthedew
Aug 16, 2008 12:36 PM
Illusive
Sep 9, 2007 07:16 PM
