Cago Cover - Is it the same for 2010 & 2012?
Old Apr 30, 2012 | 01:10 PM
ChrissyW's Avatar
Cargo Cover - Is it the same for 2010 & 2012?
Buying a 2012 and need to know if the Cargo Cover with the 5 screw ins from the 2010 will fit the new 2012.
Thanks
Old Apr 30, 2012 | 01:16 PM
cspan37421's Avatar
it's a slightly different part number at College Hills Honda
2009-2011# 08U35-TK6-110
2012+# 08U35-TK6-111
I suspect the only difference is the flap which covers the gap when the rear seats are up (apparently it's minimal when the seats are reclined). The 2012 lacks the flap, which some disliked and a few didn't bother to install anyway.
If you want to use a 2010 model cargo cover with the flap on a 2012 car, I don't know if the rear seats will still have the spots at which to anchor the flap snaps. Probably - but I don't know. I'd bet the shelf alone would fit fine.
Old Apr 30, 2012 | 01:23 PM
fittacular81's Avatar
Lol you don't want to know what "cago" means in spanish. Lol cago cover
Old Apr 30, 2012 | 01:29 PM
cspan37421's Avatar
thank you Google translate! "Talk about mud flaps..." - Spinal Tap
hey fittacular81, you don't want to know what fitta - the original name for the Fit, according to Wikipedia - means in Norwegian!
Old Apr 30, 2012 | 02:41 PM
I could sure use some norweigean fitta right about now..
Old Apr 30, 2012 | 04:02 PM
malraux's Avatar
You can feel around and see if the rear seats still have the holes. Download the install instructions and use that as a guide to feel the spots where the cover goes. If you can feel a hole there the you can install the snaps.
Of course, the flap part pops off easily, so even if you don't have them you can "convert" a 2010 cover to a 2012
Old Apr 30, 2012 | 04:41 PM
ChrissyW's Avatar
Thank you
Old May 3, 2012 | 11:12 AM
2012FitFan's Avatar
I have the cargo caover for 2012. Either year will work. Since the seats can be moved back and sit almost flush with cover, no need for the flap.
Old May 5, 2012 | 06:14 PM
cspan37421's Avatar
Just installed the clips on my cargo cover. Strangely, they weren't in the box with the cargo cover. I found them days later taped to the underside of a piece of spacing cardboard in the box my floormats came in. Anyway...
The clips are hard to get on but work carefully and start at an angle, and they'll get on there. I am glad I got the cover, even though it's a bit expensive for what you seem to get. As someone said, it finishes off the area nicely, the fit is perfect (ha ha), it snaps in nicely to the ridge on which it rests, it raises up when you open the trunk, it weighs little and, perhaps most importantly of all, it does not pose nearly the crash risk to rear passengers that a piece of plywood would. In fact, the topography of the surface suggests that it might be designed to collapse / compress in a crash.
It's probably a high margin item for Honda, but the Fit is probably not so high margin, so they make it up a bit here, a bit on the mats (for base buyers), the cargo tray, etc.
white_FIT2012
Apr 29, 2017 06:23 PM
shutterbughannah
Sep 27, 2016 09:55 PM
rcbanni
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 31, 2014 11:00 PM
ELGE8
Sep 22, 2012 12:24 PM
