Changing rims
Old May 9, 2012 | 02:18 PM
dovey's Avatar
Changing rims
Hello, do i have to align my tires after changing my rims? Im still using the stock tires. Thanks
Old May 9, 2012 | 02:23 PM
doctordoom's Avatar
Supervillain
You don't need an alignment.
You can change wheels and tires as many times as you want, the alignment isn't affected by that.
Old May 9, 2012 | 03:04 PM
illissus's Avatar
If you are putting the stock tires onto new rims, you should, however, get them balanced by a tire shop. Alignment refers to how the wheels are "aimed" and balancing will make sure the wheels themselves don't have any wobble.
Old May 9, 2012 | 03:58 PM
bmxman's Avatar
what he said!
Old May 9, 2012 | 05:44 PM
larrymcewin's Avatar
I think you're getting alignment times mixed up with wheel balance times.
New rims mean it's time to get your wheels re-balanced.
Hitting a curb means it's time to get an alignment.
Old May 11, 2012 | 09:36 AM
dovey's Avatar
Thanks...
Old May 11, 2012 | 10:15 AM
Steve244's Avatar
If the new rims are the same geometry (size) as the old ones, you shouldn't need alignment (unless the tires are wearing unevenly).
When I get new tires, I always have it aligned. Besides being a slightly different shape (if by a different manufacturer) the car takes a lot of pounding over 30-50K miles. Things shift. $70 for alignment is cost effective for getting the most miles out of a $400+ set of tires.
Old May 11, 2012 | 04:17 PM
mahout's Avatar
If your rims have significantly less offset, meaning the wheel rim sets further out from the hub, your camber has changed and because its tied to caster you need to have the alignment checked. If it was not good to begin, it will surely be worse.
Old May 11, 2012 | 11:44 PM
got2run5's Avatar
Shouldn't need an alignment. You will want to balance them though.
Rster85
May 31, 2015 10:29 AM
halfmoonclip
Jul 29, 2009 04:18 PM
Luichenwai
Jan 16, 2009 04:27 PM
misfit83
18
Oct 13, 2008 09:40 PM
Luichenwai
Sep 1, 2008 12:47 PM
