Front seat belt bolt cover mod
Old May 10, 2012 | 12:19 PM
hayden's Avatar
For those wanting to go the extra mile, this "mod" is for you. I found it while browsing some JDM rides, and quite a few people have done this. The part number should show up in USDM databases, as it is probably a common item.
It's the little things...
EDIT: and for GD owners, it appears that the same part number works.
Info: http://minkara.carview.co.jp/userid/...5234/note.aspx
Old May 10, 2012 | 02:03 PM
swflej1's Avatar
WOW didn't know those we're not there. Guess I'm ordering that next.
Old May 10, 2012 | 02:53 PM
teamkitty's Avatar
Hey great find! That always kind of bugged me. And also the exposed phillips screw on the inside door handles.
Old May 10, 2012 | 03:29 PM
hayden's Avatar
Home Depot or Lowes should have a fix for that. Go into the specialty drawers in the hardware section and look for screw caps. They come in different sizes, and have a hinged plastic piece attached to them that you would normally put a screw into. Use an exacto to trim the tab, and caulk into place. You won't notice the tab being cut off because of the way the plastic is molded. They come in black, white and tan, iirc.
Good luck, and let us know if you find something. I will do the same.
Old May 10, 2012 | 03:34 PM
hayden's Avatar
A link to order from Bernardi Parts for $4.59 ea: 81420-S5A-004ZC - COVER ANC*NH167L* - Bernardi Honda Parts and Accessories
NOTE: Only one cover is needed. The passenger side belt is already concealed by a trim piece.
Old May 31, 2013 | 02:25 PM
Tk3's Avatar
Tk3
Thanks for the seat belt cover mod. It was easy and seems like a little thing but adds a finished look to the interior.
Good advice. I didn't look before I ordered and almost ended up with an extra one.
Old May 31, 2013 | 09:22 PM
carboy's Avatar
Thank you, nice touch
Old May 31, 2013 | 10:22 PM
wat is this seat belt cover thingie? i dont remember not having a cover on my car
anyone have a zoomed out pict and location? (not near my car right now).
Old May 31, 2013 | 10:28 PM
Tk3's Avatar
Tk3
Before pic is here...
Sorry if it isn't zoomed out very much. If you're sitting in the seat behind the driver, its near the floor on the left.
Old Jun 1, 2013 | 03:01 AM
loudbang's Avatar
Good find. The only time I'm in the back seat is when it's vacuuming and cleaning time and never even noticed those uncovered bolts.
Old Jun 1, 2013 | 03:27 AM
ThEvil0nE's Avatar
good find indeed
davis22b
Mar 16, 2015 10:41 AM
vanillarican
Jan 20, 2014 10:46 PM
Wafulz
May 15, 2012 01:49 PM
the unknown97
Dec 2, 2010 12:23 PM
Black3sr
Aug 7, 2010 06:34 PM
