better mpg with electronic throttle controller ?
Old May 29, 2012 | 01:11 PM
linnboi's Avatar
anyone with experience ?
Old Jul 17, 2012 | 04:13 AM
buttersandpaper's Avatar
I had the etc throttle controller for a couple of months. It did well for saving gas & hauling you know what. But last week it threw a check engine light. Unplugged, reset the battery, & the light was gone. then I tried to reinstall it. My mistake. I blew a fuse. But I did buy it used. I maybe going with an apexi & see what happens there.
Old Jul 17, 2012 | 06:04 PM
Dwalbert320's Avatar
I took mine out as well after it sent out of range voltages to the throttle and the car went into limp mode. Gave me two fault lights and a trip to the Honda dealer. Needless to say it's not going back in.
Old Jul 17, 2012 | 06:14 PM
Wanderer.'s Avatar
I fail to see how an ETC will get you better gas mileage? I can see how putting it in sport mode would make your mileage WORSE, but I don't really see how putting it in "eco" mode would make it better? Is the throttle that hard to modulate that it's response needs to be slowed?
Old Jul 23, 2012 | 05:13 PM
linnboi's Avatar
i bought one then returned it...didn't install it.
don't feel safe about keeping it plugged in the obd scan plug thing ...
Old Aug 3, 2012 | 12:52 AM
Texas Coyote's Avatar
I use mine in the eco settings a lot when driving on the highway... The one I have is over 3 years old and has 2 separate boxes, one under the dash tape to the lower panel and the other with double stick velcro that is between is mounted above my console.. The slower response improves my fuel mileage as well as helping out on keeping the exhaust noise down.. I plan on getting a new one that is smaller from Panson because of the extra wiring that is needed for modifications that will take up room near the OBD2 connector.
Old Mar 18, 2013 | 12:27 PM
DavefromCA's Avatar
Hmmm never heard of this. I would be really iffy about messing with the throttle settings. I have more faith in the Honda engineers then a 3rd party small business.
Old Mar 18, 2013 | 02:18 PM
Wafulz's Avatar
ETC just wait for hondata lol
Old Mar 18, 2013 | 03:04 PM
Black3sr's Avatar
I have had mine so long I forget I have one. A couple years at least. I leave mine at E4. Much prefer this setting to not having one.
Now if I cold just change the bulbs to blue.
Old Mar 18, 2013 | 04:52 PM
macbuddy's Avatar
...it could be a short in the wiring...
I had the same problem with mine. It turned out to be loose wiring which I was able to fix by re-soldering said contacts. If you are interested, here is my fix. You can read the entire thread, or go directly to post #13:
Stuck in 4th gear...BLITZ TC? - Honda Fit Forums
twpanson
611
Nov 11, 2014 01:58 AM
Myxalplyx
Nov 10, 2014 09:10 PM
royalflush313
Mar 9, 2010 06:55 PM
modfit669
Dec 27, 2009 03:24 AM
da9r00d
Jul 21, 2009 01:24 AM
