Engine rev "float" normal?
Old Jun 17, 2012 | 12:02 AM
Goobers's Avatar
Originally Posted by Steve244
Sorry, dog, how's it going to eliminate throttle hang by "making the response quicker." And what does quicker mean? Introducing any device between the gas pedal position sensor and the ECM can only increase latency. It doesn't read your mind.
It can open the throttle more than normal (or less) when you press on the accelerator pedal. But releasing the pedal results in an immediate throttle closed signal regardless of what devices you place between it and the ECM. Without altering the ECM's logic to close the throttle slowly, it will continue to do so.
Putting a third party device that alters the signal from the gas pedal to the ECM while making a parasitical electrical connection to the OBDII port seems like a really bad idea. Having wires hanging all over is ugly too.
Try moving your foot more (or less).
I think the question here is: are you sure it only goes between the pedal and the ecm? What if, through the OBDII port, it inserts itself between the ecm/pedal AND ecm/throttle connections, effectively bypassing the ECM?
Old Jun 17, 2012 | 12:56 AM
Texas Coyote's Avatar
The argument based on some other persons misconceptions means absolutely nothing to me... It reminds me of some one that saw a low budget war movie based on a novel by a person that had never been in a war trying to tell me what it was like to be an 18 year old Marine in a A Shau Valley for 56 days in 1969.
Old Jun 17, 2012 | 02:30 AM
Potenza's Avatar
Rev hang is something that has driven everybody with a HONDA equipped with manual transmission crazy for the last 6 years...
fixed
Rev hang annoyed the hell out of me at first but I got used to shifting the car quick and pretty much forgot about it.
Old Jun 17, 2012 | 09:39 AM
Steve244's Avatar
No way. This would require effectively corrupting the ECM to operate differently. All it can do is alter inputs to the ECM. Since it's on the pedal side of the ECM that's what it does.
Old Jun 17, 2012 | 09:48 AM
Steve244's Avatar
Originally Posted by SilverBullet
What's your point, bullet? That the Fit has DBW? That's a very nice page describing it, but it doesn't advocate putting third party "made in China" boxes to alter the input to the ECM.
Old Jun 17, 2012 | 09:52 AM
Steve244's Avatar
Another case of a person with no first hand practical knowledge of what he is talking about and therefore doesn't understand making shit up as he goes... There are guys on here that have a hell of a lot more money in their Fits and race them that use ETCs.. I have used one for over 3 years... How long have you had one on a car or are you just searching out counter remarks from other opinionated people with no first hand knowledge about how things work... The damned thing closes the throttle when you lift your foot as immediately as it opens or as slowly if using the Eco settings...... Don't be lying to people about things that you have no personal experience with.
Sorry, Dog. Altering the ECM logic (reflash) will have the effect you're describing (you are running an aftermarket tune on your GD, right?). The box that goes between the pedal and the ECM will not. The throttle closes no faster than Honda programmed it in order to lower emissions. Think about it.
Old Jun 17, 2012 | 05:07 PM
Goobers's Avatar
The problem is, you are stuck on the assumption it only connects between the pedal and ecm.
The ecm still has to OUTPUT a signal to the throttle body, and that can easily be interrupted/intercepted. You don't have to alter what the ecu is outputting, just what the throttle is receiving. Again, bypassing the ecm, not manipulating it.
I don't know the details... and I'll admit I have no experience with it... but I'm not going to make the foolish assumptions you're making.
Old Jun 17, 2012 | 06:07 PM
Steve244's Avatar
The aftermarket throttle controllers do not connect between the ECM and the throttle. What you are suggesting is somehow the designers managed a real-time ECM hack via the OBDII port to alter the throttle logic. No one (to my knowledge) is even marketing an aftermarket tune for GE ECMs. All these do is change the amount of pedal signal to the ECM. It gets power to retain settings from the OBDII port.
Old Jun 17, 2012 | 07:23 PM
Goobers's Avatar
Okay, I admit the assumption of having an ecm to throttle interrupt is wrong.
I think I'll excuse myself from this thread now.
Old Jun 17, 2012 | 10:10 PM
specboy's Avatar
I'll hop in on this one just from a logic standpoint.
If the stock throttle control registers the throttle body at the following rate (These are Examples, not actual numbers);
Pedal | Stock % | ETC %
10% | 15% | 20%
20% | 30% | 40%
40% | 60% | 80%
50% | 75% | 100%
66% | 100% | N/A
... doesn't the throttle respond more quickly when the pedal is being pressed and released? I think that there's an assumption that the throttle returns to 0% Position at a set rate and not based upon the position of the pedal. Is this a known fact and if not, the spring/return rate of the pedal would determine the throttle response. In this case an ETC would help increase the rate of throttle response in both directions.
~SB
Old Jun 17, 2012 | 11:26 PM
doctordoom's Avatar
Supervillain
Do any of you actually have an electronic throttle controller, or are you all just arguing based on your infallible logic?
I've had an electronic throttle controller, it does not help reduce throttle lag/hang. All it does is alter how the throttle perceives the gas pedal position. For example, it can trick the throttle into reading a floored pedal when in reality, you're only pressing the pedal halfway. However, the throttle still responds only as quickly as when you slam the pedal to the floor as fast as you can.
It doesn't accelerate the signal to the throttle. It doesn't lighten your flywheel for a faster engine response. It's just a piggyback that alters the throttle signal, Steve244 is right.
Old Jun 17, 2012 | 11:29 PM
  #32
doctordoom's Avatar
Supervillain
I get your logic Specboy, and in theory, it does make sense. However in reality, the difference you propose, whether or not it is real, is microscopically minuscule and literally imperceptible. It would be the same as slamming your pedal to the floor and quickly letting it up to attempt getting a quicker rev response. At that point, the throttle position is no longer a limiting factor in the engine's response.
Old Jun 18, 2012 | 07:49 PM
  #33
specboy's Avatar
I'm thinking that the TB is controlled by a Servo and most all servos have the same speed capability in both directions so the TB response would be dictated by the position of the pedal. tighten up the positioning of the pedal in relation to the servo and you have quicker response. That said, it isn't going to change the flywheel speed without some weight reduction on that end. The combination of a lighter Flywheel and a throttle controller I would think would be the best overall option to reduce rev hang.
As for actual response, I think it'll be greater than what any of us (without one) would think but not as absolute as basic logic would dictate.
That said... I think I still want one .
~SB
Old Jun 18, 2012 | 07:59 PM
  #34
wontfit's Avatar
I think the real issue here is that you can't get the throttle 100% open no matter what. Iirc the gd chassis at wot was only open 80 of the way. That chart shows 100% but I believe it means 100% of the programmed 80% functionality. Hopefully someone followed that
Old Mar 19, 2013 | 10:28 PM
  #35
Delraco's Avatar
Sorry for reviving a bit of an old thread, but the rev hang on my fit is so bad that I want to sell it after only two months of ownership.
I deleted the CDV in the first week. That's out of the question.
Throttle controllers have always been just a signal modifier. The ECM has separate values for how much it blips the throttle based on detected unburned fuel residing in the cylinders/intake charge between shifts. Whether it calculates that amount of fuel based on throttle position when the clutch is depressed or fuel pressure at the moment the clutch is depressed I know not. Maybe it's both, maybe it's something else like injector pulse. I don't know.
I picked up a barely used 2009 Mazda3 which is communicative and responsive in every way compared to the Fit. I love it.
Seriously considering selling my Fit already even after only 590 miles.
Unless I can get a reflash that makes this rev hang disappear, I'm going to make this damned car disappear.
Old Mar 21, 2013 | 08:58 AM
  #36
SilverbulletCSVT's Avatar
The ETC eliminated the rev hang before I did the high boost upgrade and got the ECU reflashed.
Glad this old thread got revisited. I had no idea that the ETC eliminated rev hang. I considered a ETC for other reasons before but never pulled the trigger. Now I will definitely be buying one to get rid of rev hang. Next up will be replacing the funky valved clutch slave cylinder to get normal clutch feel. Those two things are my only pet peeves with the Fit.
_
Old Mar 21, 2013 | 05:02 PM
  #37
Steve244's Avatar
_
Save your money, it can't work magic. Coyote has his ECU's re-flash confused with the overpriced-aftermarket box (ETC) that goes between the gas pedal and ECU.
Old Mar 21, 2013 | 05:47 PM
  #38
doctordoom's Avatar
Supervillain
^ True. The ETC does nothing for rev hang or throttle lag. Some people don't seem to understand the difference between magnitude of throttle response versus the responsiveness of throttle input.
The Hondata flashpro is supposed to do something with rev hang and/or throttle response, but I haven't tried it out yet and after seeing all these testimonies about the effects of an ETC, I'm not going to believe anything unless I try it myself.
Old Mar 21, 2013 | 08:18 PM
  #39
Well see above post. He clearly stated his rev hang was eliminated before he did the other mods.
_
Old Mar 21, 2013 | 08:29 PM
  #40
Wanderer.'s Avatar
What's the beef with the rev-hang anyway?
