prm intake question
Old Jul 18, 2012 | 06:45 PM
linnboi's Avatar
prm intake question
do we get cooler air with this intake ?
Old Jul 18, 2012 | 07:02 PM
Triskelion's Avatar
You get the same temperature air that you got with your stock intake. The PRM system picks up air in the exact same place as stock. What you get is MORE air and a little more noise, because the PRM system eliminates the bends and baffles of the stock intake that are there to reduce noise. By increasing the flow of air into the engine (and reducing restrictions of the stock system), the PRM gives you more HP and torque than the stock system.
Old Jul 18, 2012 | 07:42 PM
linnboi's Avatar
sweet ! are there any high flow cats that are street legal for ge8s ?
Old Jul 18, 2012 | 07:59 PM
Triskelion's Avatar
Maybe there are, but they would not be "legal" in CA. When your Fit reaches 5 years old, any smog check tech. who can spot your after-market "cat" converter would fail your smog check. Same story with the PRM intake. The intake would be MUCH more simple to swap back to stock for a smog check than the "cat". You would not gain enough performance to justify all of the b.s. involved with the "cat". The PRM intake is a good buy and will justify your expense. I can't say from experience if the "cat" converter would do the same. I sincerely doubt it.
Old Jul 18, 2012 | 08:14 PM
linnboi's Avatar
I'm in nj now. Probably not legal ... High flow cat seems interesting. Used to have a straight pipe on a type r. Sounds great and loud ... Figuring the high flow cat will be less loud ad yet power yielding
Old Jul 18, 2012 | 08:18 PM
Triskelion's Avatar
Ooh! Sorry that you had to trade Chino, CA, for anywhere in NJ! Except, maybe, The Pine Barrens. From my trips there, NJ sucks. Any mod that you do that circumvents the smog controls will probably pass in NJ. But good luck breathing while you are there.
Old Jul 18, 2012 | 08:19 PM
linnboi's Avatar
I'm in nj now. Probably not legal ... High flow cat seems interesting. Used to have a straight pipe on a type r. Sounds great and loud ... Figuring the high flow cat will be less loud and yet power yielding
Old Jul 18, 2012 | 08:20 PM
linnboi's Avatar
Yep, I was only in ca for 3 months actually
Old Jul 18, 2012 | 09:33 PM
linnboi's Avatar
read that the cusco strut bar requires cutting of the intake duct ... so i wouldnt be able to get that then right ?
Old Jul 19, 2012 | 12:07 AM
Triskelion's Avatar
The PRM intake will be worth a LOT more to your Fit's performance than ANY strut bar. The front struts do not move. Strut bars are just for looks, and the look is silly. but do whatever you want.
Myxalplyx
Apr 11, 2015 09:56 PM
Vash
Jan 18, 2010 11:15 AM
jjninnottingham
Mar 24, 2009 07:02 PM
Rod2Rice
Jul 24, 2008 11:06 AM
F0NIX
Feb 18, 2007 07:10 PM
