Question on T1R B-Pipe
Old Sep 26, 2012 | 11:44 PM
mo-FUK's Avatar
I installed the B-pipe and i notice that it rattles like if its hitting on something, can someone help me out with this problem because its a bit annoying hearing that rattling sound on a red light
Old Sep 27, 2012 | 05:38 AM
Dwalbert320's Avatar
The reason it is rattling is because it is hitting something.
It was not installed properly.
Take it back to the shop who did the work and have them fix it. If you installed it yourself check your work.
Old Sep 27, 2012 | 08:44 AM
mo-FUK's Avatar
its hitting the frame and i don't know what to do so the noise can stop
Old Sep 27, 2012 | 09:44 AM
NIGHTHAWKSI's Avatar
stop it from hitting the frame and the noise will stop....
Old Sep 27, 2012 | 02:12 PM
Wafulz's Avatar
^^ HHAHAHAH put big papper ball
Old Sep 27, 2012 | 02:48 PM
SickFit's Avatar
Mo-Fuk, The rattling is coming from one of two places. 1) It's either coming from the beginning of the B-Pipe at the first bend where there is an aluminum heat shield that it is vibrating against. The shield can be bended or cut in that area where it's touching the pipe.
or
2) if you have an aftermarket axle-back, then the axle-back and the B-Pipe combined is causing the alxe-back pipe to hit the frame of your car. This is easily fixed by adjusting the rubber bushing holding the axle-back in place.
Both were happening to me and that's how i solved both noises.
Old Sep 27, 2012 | 02:58 PM
Wafulz's Avatar
+1 for Sickfit
Old Sep 27, 2012 | 03:18 PM
mo-FUK's Avatar
It's on the first bend to the cut off part because the sound comes right from under the passenger seat. I think I am going to have to adjust the blushings because it might be to far in... Thank you I'm going to see if that does the trick. I hope it does
Old Sep 27, 2012 | 03:21 PM
SickFit's Avatar
It's the heat shield/car frame near that first bend then. Let me guess, it rattles even louder when you put the car in reverse?
Old Sep 27, 2012 | 03:23 PM
SickFit's Avatar
Originally Posted by Wafulz
+1 for Sickfit
I'd like a "like" button for this post.
Old Sep 27, 2012 | 10:38 PM
mo-FUK's Avatar
it was the heat shield, i removed it after work but now the only rattle is coming from the cat back. I'm going to try tightening down more to see if that stops it....
you know exactly whats going on. can i stop the rattling from the cat back?
Old Sep 28, 2012 | 10:37 AM
SickFit's Avatar
The cat back? Do you mean the Alxe-back? Sry i just want to make sure that we're on the same page? If you do mean the Cat back, then what location from the cat... back are you refering too?
The other location that I think you are producing noise is from the end of the B-Pipe that connects with the axle-back where the pipe is near or almost on the frame when that bend of pipe goes over the frame. If so, your bushing needs to be adjusted and I can tell you which one with pics of my car. but please confirm first the other stuff above ^^^
Old Sep 28, 2012 | 12:37 PM
mo-FUK's Avatar
sorry, yes i meant axle-back... please that would help
Azizul Zulzaha
53
Aug 7, 2014 02:18 PM
ajp2k3
May 31, 2014 01:28 AM
Nighthawk_GD3
Sep 23, 2009 09:06 PM
doctordoom
Apr 6, 2009 11:34 PM
ericman20
28
Jun 13, 2008 11:32 PM
