Installing Driver's Seat Mounted Sport Armrest on Base
Old Oct 2, 2012 | 04:52 PM
warren561's Avatar
Does anyone know if the GE Base Model driver's seat is the same as the Sport Model driver's seat?
In particular, I'd like to know if the Base Model driver's seat threaded nut installed inside the seat frame. I'm talking about the threaded nut in which the driver's seat mounted arm rest (from a sport model) could be installed.
The armrest console instructions show's what I'm talking about on the left side of page 2.
http://www.collegehillshonda.com/ins...13/armrest.pdf
I'm interested in adding the seat-mounted arm rest to a base model Fit. Not interested in the console mounted armrest, as I don't want to lose a cup holder there.
Thanks in advance!
Old Oct 2, 2012 | 05:17 PM
that's a good question.... is that mounting part metal on the sport's seats? would placing a magnet on your base seat in that area determine if there's a metal bracket under the cloth?
can you poke around that area to see if you can make out those 4 holes?
might be easier to source a used sport seat from someone that swapped out with aftermarket seats?
Old Oct 2, 2012 | 05:19 PM
Wanderer.'s Avatar
I'm gonna go do this right now because i'm really hoping this is the case
No bracket or anything under the fabric I can feel on my 2010 base unfortunately...
Old Oct 2, 2012 | 05:29 PM
Rampo's Avatar
Thanks in advance!
Do you already have the armrest? If you find out if the seat has the mounting hardware, I have an extra if you need one.
warren561's Avatar
Follow up...
I did some more digging and I found a parts diagram from Majestic Honda - The Internet's #1 Honda Automotive Parts Store
From what I gather, I need two of #7 (as shown in the PDF console mounted arm rest, page 2, step 3) and 1 each of #10, #6, #9, #8, and of course #12.
I found the above diagram under "System Name\Component : FRONT SEAT (L.) (KA/KC)" however, it doesn't list part numbers or descriptions for #7, #10, #6, #9, #8, or #12. I suspect that it is found under a different section.
Old Oct 2, 2012 | 05:37 PM
boo~. that sucks. i didn't even know my '12 sport had the minivan arm-rest until after i took delivery. hahaha.
i was going to get the factory armrest option since i can store stuff inside and my 09 has one. im not a huge fan on that folding arm rest to tell you the truth. it's too high for MT shifting.
Old Oct 2, 2012 | 06:21 PM
warren561's Avatar
Nuts!
Sounds right since I just noticed that the driver's seat frame part numbers are different between the sport and base models.
Sport: 81526-TK6-A21 (assuming this frame has the holes/bracket for the armrest bolts)
Base: 81526-TK6-A01
Thanks for checking though!
I don't have the armrest. I appreciate the offer, but I don't think I'll need it.
Old Oct 2, 2012 | 10:52 PM
Codi's Avatar
2012 Honda FIT|
I found the same diagram, it has the descriptions for each part. Think that may help.
I actually just installed the center myself the other day. If you get a decent armrest, or from someone, it should have parts #10, #6, #9, #8, and #12. I held onto those myself, and #7 is still on my car. Bought a cover for the hole in my seat from someone on here.
Old Oct 3, 2012 | 06:59 AM
specboy's Avatar
I use the armrest regularly becuase it is better than nothing and after 3 years of ownership, it has deformed and become hard/uncomfortable if I'm driving for more than about 5 minutes. It was a lousy add-on when Honda threw it in there and is NOT worth spending even your time on. I have on my Christmas wish list the center armrest console as the flip down seat mounted thing didn't even last me 30K miles. I don't put a lot of weight on it either.
~SB
Old Oct 3, 2012 | 10:42 AM
huh, i didnt know this was an 'option' on the 09's. my 09 came with the dealer-installed one with the cubby. this is why i didnt know my '12 had that minivan armrest until after taking delivery. hahahaha. i was for sure going to order that arm rest with cubby but pleasantly surprised i didnt need to.
i only use it on long trips. for surface road driving it just gets into the way of my MT shifting.
Old Oct 3, 2012 | 01:26 PM
x_25's Avatar
I bought and installed the honda center arm rest/console thing. It has been very nice so far. And don't believe them when they say it can't be installed on the MT fits, they lie.
Old Oct 4, 2012 | 09:41 PM
specboy's Avatar
It wasn't an "option" but standard on the '09s. By Add-On, I was aiming for "Afterthought" as it really was a crappy piece of hardware they installed.
~SB
Old Oct 4, 2012 | 09:45 PM
~SB
no way~. my 09 GE sport AT does not have that arm rest.
Old Oct 4, 2012 | 10:10 PM
specboy's Avatar
your 09 doesn't have the flip down minivan armrest attached to the seat? I could have sworn it was standard on all Sport models.
~SB
Old Oct 4, 2012 | 10:24 PM
~SB
nope. that's why i didnt know these FitSports came with one... i didn't even notice it on my '12 until the drive home from the dealer.
Old Oct 5, 2012 | 01:00 PM
FitStir's Avatar
Didn't you mention that your 09 had the center console armrest?
If so then when the dealer installed the center armrest, they had to remove the minivan style mini armrest on the drivers seat, otherwise the center won't fit.
If you don't have the center armrest, check the drivers seat in the location where it's supposed to be and see if there is a plastic "cover"/"plate" (for the lack of a better word) that covers that area it's like a square if I recall correctly. If it has the cover then someone uninstalled the mini van armrest.
If I'm not mistaken ALL 09+ Fit Sports have the mini armrest. My 09 MT came with it, but I had to remove it when I installed the center console.
Desmond Lamar MacRae
May 20, 2014 06:28 PM
Josephkao
Aug 24, 2010 04:03 PM
shegetstodriveit
Asia Fit Forums & Clubs
Mar 22, 2010 01:42 PM
erdahlj
Dec 13, 2009 08:17 AM
keevohn
Jan 6, 2009 04:49 PM
