Auto door locks
Old Nov 14, 2012 | 02:56 PM
daves007's Avatar
Auto door locks
09 Fit Sport Auto, is there a way to disable the auto door locks ? Thanks.
Old Nov 14, 2012 | 03:04 PM
nikita's Avatar
Yes. The instructions are in the Owners Manual. I did it over two years ago, so dont remember the details.
Old Nov 14, 2012 | 03:40 PM
completely or the auto lock when you speed up past 10mph? check your owner's manual for the latter.
Old Nov 15, 2012 | 09:46 AM
daves007's Avatar
Bought it used, no manual.
I would like to disable the autolocks when parked.
Thanks, Dave
Old Nov 15, 2012 | 09:52 AM
Brain Champagne's Avatar
Manual is on-line available for free download from Honda and I think there were three settings- open driver's door when parked, open all doors, or do nothing.
Old Nov 15, 2012 | 11:12 AM
daves007's Avatar
Do you have a link, I can't seem to locate it other than the CD version on Amazon. Would love to have a copy.
If not could you explain what it says to do in the manual to disable? Thanks very much.
Old Nov 15, 2012 | 11:28 AM
My OM (2010) is called K61010OM.pdf and if you google it you should be able to find it somewhere.
Old Nov 15, 2012 | 11:33 AM
komafit's Avatar
You should be able to get a pdf of the owners manual through Honda Owners Link: https://www.ahm-ownerlink.com
Old Nov 15, 2012 | 01:02 PM
daves007's Avatar
Thanks, that is exactly what I needed.
Old Nov 15, 2012 | 01:13 PM
daves007's Avatar
Here are the instructions to disable the autolock: In park w/car off,,, Turn the ignition switch to ON (II) position, and open the driver's door,,, Push and hold the front of the master door lock switch on the driver's door until you hear a click (after about 5 seconds),,, Release the switch, and within 5 seconds, turn the ignition switch to the LOCK (0) position.
In case anyone search's for the answer. Thanks again for the reply's.
Old Nov 20, 2012 | 06:29 PM
unethikl's Avatar
My service manual has the steps only for automatics.
Can you disable EVERYTHING on a manual trans?
Sep 7, 2018 10:39 AM
Sono
Jun 21, 2017 11:08 PM
tom the snakeman
Feb 25, 2012 05:06 PM
Poncho
Feb 29, 2008 01:14 PM
Horky
Sep 22, 2007 09:01 PM
