Stoopid Question....
Old Dec 7, 2012 | 01:03 PM
Fatbrando's Avatar
The rearview mirror. What is the standard starting position? Is it the lever pulled forward or the lever pushed back?
Thanks
FB
Old Dec 7, 2012 | 01:25 PM
Speedlimitz's Avatar
Pretty sure it's pulled towards the driver
Old Dec 7, 2012 | 01:34 PM
YouKantPimpInaKIA's Avatar
On mine....
Away from driver...Daytime
Thinking about it, it might just work either way, depending on where you start?
Old Dec 7, 2012 | 01:39 PM
Vanct's Avatar
I have mine pushed back, so it's not visible. Then pull forward for night mode.
edit:^beat me to it
Old Dec 7, 2012 | 01:45 PM
Wanderer.'s Avatar
Was actually thinking about this the other day.
Old Dec 7, 2012 | 01:59 PM
Subie's Avatar
Thanks
FB
Good title choice... Whatever works for you! Idea is deflecting the glare of headlights at night!
Old Dec 7, 2012 | 02:02 PM
AdvansCPAP's Avatar
Either position works. I prefer it to be towards me though.
Old Dec 8, 2012 | 12:41 AM
kgb4187's Avatar
Depends on if you want the light reflected onto the ceiling or onto the back seat (where passengers might be)
Old Dec 8, 2012 | 06:27 AM
Type 100's Avatar
Forward is the normal position.
The only time you should be pushing it away from you is if you're being followed by a car with high beams on, and you're getting dazzled. This "night" position changes the angle of the light so that it doesn't go toward your eyes - instead it gets angled downward towards the back seat.
Old Dec 8, 2012 | 09:07 AM
DrewE's Avatar
According to the owner's manual (at least for the 2012 model year), toward the windshield is the daytime position and towards the rear of the car is the nighttime position. Which lever position is "forward" and which is "back" is a matter of perspective, I guess. Doing it backwards still works.
The day/night mirrors are more clever than you might at first realize. The glass is slightly wedge-shaped. In one position, the image is reflected from the mirroring in back of the glass, as with most any mirror; in the other, the light you see is reflected off the front surface of the glass, which is a much poorer reflector. That's why you can still see something in the night position, but don't get dazzled (as much).
With the settings reversed from standard, the "wrong" night position still gives an image; I think the light is being reflected off the silvering, off the surface of the glass back to the silvering, off the silvering again, and too your eyes.
Old Dec 8, 2012 | 12:27 PM
Wanderer.'s Avatar
Yes, as far as I remember the "switch" should be forward for normal and back towards the driver for glare avoidance. DrewE is right in that the mirror is somewhat "smart" and you can still see out the back window through the mirror with it in the back position, but it is very dim.
I have had Broadway mirrors on for so long I don't remember exactly. In this case I do use the forward for normal and back (towards driver) for anti-glare at night, but this just puts the light on the roof with a Broadway mirror.
Old Dec 8, 2012 | 10:08 PM
MrBlueS2K's Avatar
Yes what they said
Old Dec 8, 2012 | 11:18 PM
Perrenoud Fit's Avatar
well there's not a lot to say about this that hasn't already been said,
SilverEX15
Oct 23, 2014 07:44 AM
m-man@sbcglobal.net
Sep 3, 2011 12:47 AM
urbanmic
Apr 24, 2010 08:39 PM
DeadlyAcuraccy
Oct 23, 2008 04:04 AM
Gordio
May 24, 2006 05:05 PM
