Auto-up window switch broken?
Old Apr 2, 2013 | 03:07 PM
larrymcewin's Avatar
I'm a bit bummed. After 18 months of 100% trouble-free Fit ownership, my car is having it's first "broken part" moment.
Anyone else have trouble with the auto-up switch? It's like something trips the switch and kicks the window back down.
It works fine if I hold the switch up myself. But still, that's really annoying. Any ideas how to fix it? I think I'm beyond my bumper-to-bumper warranty (driven 42k miles).
Thanks!
Old Apr 2, 2013 | 03:23 PM
Steve244's Avatar
It has a resistance sensing circuit that avoids decapitations (or de-pawifications). It needs calibrating. I'll look up the procedure and post it (hopefully it can be done without invoking the Honda electrical guy.
Old Apr 2, 2013 | 03:25 PM
fitchet's Avatar
Did you purchase this vehicle new?
If so I think it would still be under warranty. It's basically 3 years bumper to bumper.
I think you've hit it on the head, it is as if something "trips the switch" and it starts to lower.
I believe these windows are designed to sense an obstruction and lower. Something may be tripping that sensor and/or that sensor might of become defective.
Obviously the easiest thing to do would be if under warranty have the dealership fix it.
Old Apr 2, 2013 | 03:38 PM
Steve244's Avatar
3 year 36K bumper to bumper.
Here's the procedure to calibrate the anti-pinching function (no kidding that's what it's called). Haven't played with it but it doesn't require tools/instruments. pdf link
Old Apr 2, 2013 | 04:20 PM
2012FitFan's Avatar
Another great post by Steve!
Old Apr 2, 2013 | 04:35 PM
Wafulz's Avatar
Shit i knew it
i thought there was somthing wrong mines does that too grrr
Old Apr 3, 2013 | 01:27 AM
That must be it. I just played with the switch ONCE with the car off, similar to the PDF you post, and now the window works perfectly!
Thank you, Steve!
Old Apr 3, 2013 | 02:17 AM
loudbang's Avatar
More than likely it's just crud in your window channels. The crud causes the window to need more force to go up and the "anti-cut your head off" system kicks in.
Simply lube your window tracks and this will go away. I use silicone spray but some people go nutzo over it's use and have their own recommendations.
But I have done mine as a matter of course with silicone spray every 5,000 miles as part of my normal maintenance and no problems none, nadda, zip, zero, zilch.
rocksnap
Jul 27, 2024 01:59 PM
Boodee
Aug 12, 2015 12:27 AM
awsiany
Oct 27, 2014 09:25 AM
SilverEX15
Aug 21, 2014 03:07 PM
Body2Big
Jun 16, 2014 03:14 PM
