Fit Base 12V accessory socket replace questions
Old Apr 26, 2013 | 10:18 AM
over40pirate's Avatar
Does anyone know how to remove the panel that the 12V accessory socket is mounted in?
If there is room, I want to mount 2 more sockets, next to the orig.
Old Apr 26, 2013 | 11:14 AM
cfran55's Avatar
Remove that top part first the one under the ac knows the diagonal piece above the accessory socket
Old Apr 26, 2013 | 11:51 AM
13fit's Avatar
If you do this, either use a relay off the factory wiring and use battery power, or limit your power draw to 10 amps.
I have a 150watt power inverter, and while I have NOT blown a fuse yet, the wire does get warm. So the only time I plug my laptop in is if Im on very low battery and need to get a few more minutes of use from it.
Keep in mind, if you use a relay, then your power limit once the battery wire is hooked up is limited to the accessory you install. Most are 10-20 amps at max, so you may have to run 2 seperate if you run two plug sockets
Old Apr 26, 2013 | 12:55 PM
use something like this interior tool to pull down the diagnal piece just above it. can find cheaper at harbor freight.
5 pc. No-Scratch Tools for Removing Fastener & Molding : Amazon.com : Automotive 5 pc. No-Scratch Tools for Removing Fastener & Molding : Amazon.com : Automotive
Oneoldphlaytis
Jan 12, 2016 11:28 PM
SilverEX15
Aug 13, 2014 06:52 PM
epijimenez
Jun 28, 2014 12:00 AM
Bennett0415
Aug 17, 2012 12:24 PM
hogsniper
Mar 13, 2008 06:22 PM
