Please help!
Old May 15, 2013 | 12:36 AM
BlueCell's Avatar
Originally Posted by connor55
So, they've somehow got a non-projector hid headlamp?
Never heard of that before.
And for those putting HID Pnps in their stock housings: it looks like shit, and you're blinding oncoming drivers near and far away from you.
I don't care how good you think your "cutoff" is. I see idiots driving around with these everyday... They probably think they look "badass". Sigh.
Actually I can name 2 cars off the top of my head that have HID setups with no projectors. First is the Toyota Avalon and second is the Cadillac Escalade.
Edit: Also JDM housings most likely don't have any shielding in the housing.
Old May 15, 2013 | 12:47 AM
connor55's Avatar
Cool, well now I know they exist. I wasn't saying they didn't exist btw, just that I haven't heard of them.
Doesnt justify shitty PNP kits by any means though.
Old May 15, 2013 | 06:13 AM
bakurbasilie's Avatar
HID headlamp with reflector housing do exist on many JDM models, and mostly they are an optional item.
Some of the models that are available with HID headlamps are Fit GD and GE, 1st gen Stream, Civic FD, Honda Inspire, Integra and many more.
The noticeable difference between HID and halogen housings are the small little tower inside the reflector near where the bulb is, and they have different reflecting properties from the standard halogen housing so they do not blind other drivers.
And that JDM headlamp will not fit into the USDM Fit, unless you want to change the headlamp mountings yourself (I tried mine, and it doesn't fit.)
Old May 15, 2013 | 12:19 PM
Imfit12187's Avatar
wow thanks for all the feedback guys!!
what about the tail lights? same idea? they will not fit in a usdm?
Old May 15, 2013 | 12:24 PM
Imfit12187's Avatar
Old May 15, 2013 | 12:32 PM
xxryu139xx's Avatar
should fit. my axis style tails came with a pair of adapters that directly plug in.
Old May 15, 2013 | 05:29 PM
connor55's Avatar
Taillights will definitely fit, it's just that depending on the type you get you'll have to get bulb adapters or new bulbs. On the JDM base tails for example, Im pretty sure you need to loosen one of the wires to allow the connector to reach the bulb.
Old May 15, 2013 | 06:14 PM
Imfit12187's Avatar
any pictures of this procedure or diy thanks!!
Diversion
Jan 7, 2016 04:00 AM
ChiisaiTomato
Nov 2, 2014 01:01 PM
SumYunGai
16
May 29, 2010 03:20 PM
pwnstar
Jan 14, 2009 07:08 PM
accordguyintake
Aug 25, 2007 08:08 PM
