Replacement brake pads
Old Jun 18, 2013 | 10:45 PM
nukeme70's Avatar
Odd that there isn't a generic topic on this already (or I can't search worth crap), but its' that time...
After 92,xxx miles, it's time to change my disk brake pads. The stock ones that came on the car have served me fine, so I don't see much need to look for something different. I was going to order a set from College Hills Honda, unless someone were to convince me otherwise - either better performance/same price, or better price/different dealer.
I've changed pads many times on other cars, but never on my Fit...any tricks, advice, pointers, etc.?
Thanks ya'll!
Old Jun 19, 2013 | 01:30 AM
loudbang's Avatar
There are several brake pad threads funny enough in the BRAKE forum.
Old Jun 19, 2013 | 09:13 AM
nukeme70's Avatar
And that, ladies and gentlemen, is why I should explore this forum more!
I just log in directly to the 2nd Gen section and typically don't see any other sections.... Odd though that the search for "brake pads" pulls up several non-related topics scattered throughout the entire forum.
Thanks - heading over there now!
Old Jun 19, 2013 | 12:40 PM
p nut's Avatar
If stock worked fine, then I would stick with stock. They'll probably last longer than some of the performance brands anyway. I would do the rotors at the same time. Easy peasy to do. Unlike my Land Cruiser...
Old Jun 19, 2013 | 01:03 PM
Jephu's Avatar
OEM: $48.58 final price shipped to your door
2009 HONDA FIT Parts - CurryAcuraParts4Less
Duralast Gold Cmax: $59.99+ tax @ Autozone. Lifetime warranty, never have to pay for brake pads again.
Duralast Gold Cmax/Brake Pads - Front (DGC1394) | 2009 Honda Fit 4 Cylinders 1.5L VTEC SOHC | AutoZone.com
Old Jun 19, 2013 | 01:31 PM
p nut's Avatar
I wasn't too impressed with the AZ Duralast Gold pads. On just about every single one I've owned, they caused rotors to "warp." Never had a problem with Axxis, Hawk or OEM. Lifetime warranty is good, but I stay clear of those personally.
Old Jun 19, 2013 | 01:49 PM
cfran55's Avatar
Do you really need to resurface the rotors when changing brake pads? I'm thinking of just swapping hawk pads and be done. Eventually get a set of hawk quiet rotors.
Old Jun 19, 2013 | 02:40 PM
p nut's Avatar
You don't necessarily have to resurface rotors. The idea is to match the surface of the pads to the rotors. If you're using old ones, it's harder to match the grooves and such. New or resurfaced are easier, since you're starting with a flat surface. This is also why the "break in" procedures require hard braking (to mate the surfaces).
But I've never had good luck with resurfacing. And they're so cheap that I just buy new ones. Unlike their pads, I have had really good results from Duralast rotors (NOT Valuecraft--avoid those like the plague). I believe they were $70 for two, the last time I bought them. Replacing is a cinch.
Old Jun 19, 2013 | 06:30 PM
CasualFitOwner's Avatar
Tip: If the rotor screw doesn't come out, watch ETCG Youtube video on how to remove the screws. I've used the double hammer method followed by impact driver (not wrench) to remove the stuck screws.
I used Honda pads and brembo solid rotors, as the rotor had a deep groove.
new rotor screws part #: 93600-06014-0H
Honda pads: 45022-TK6-A00
Brembo rotor: W0133-1784756.
Old Jun 19, 2013 | 11:26 PM
nukeme70's Avatar
[QUOTE=Jephu;1188109]OEM: $48.58 final price shipped to your door
Thanks for the link - I priced them and College Hills Honda - Curry Acura was about $1 higher...until CHH adds in about $15 shipping! Great deal from Curry with the free shipping.
Thanks again to all ya'll (that's plural here in TX) for your help and advice.
Old Jun 20, 2013 | 12:00 AM
p nut's Avatar
Those screws serve no purpose. Just there at assembly to hold the rotor in place. Your wheel holds it in place, so no need for it. I would NOT replace them. Stubborn ones in the past, I just drilled out. Lot easier than messing with impact driver and hammers.
If you want to replace them, for some weird OCD reason, smear a glob of anti-seize on the screws.
Old Jun 20, 2013 | 08:49 AM
mahout's Avatar
Thanks ya'll!
There are many aftermarket pads available for less than Honda prices; but for our shop we install Hawk HPS simply because our customers don't drive like they are texting.
If you've changed disc brake pasds before you'll have no problem with Fit.
PS note the disc spelling, not disk, when you search here for the thousands of posts on replacement pads.
Old Jun 22, 2013 | 08:19 AM
specboy's Avatar
Hence the need for a Forum Reorganization PRIOR to the 3rd Gen coming out. All generation information should be lumped in one location, not by topic.
As for the Pads and rotors, I'd do both since it is only the front rotors. Resurfacing is tough these days as the rotors are usually fairly thin and don't have much material to remove. plus, doing so makes them even thinner and more succeptible to warping (and sooner need to replace them and the pads again.)
I've ordered from rockauto before and got high quality rotors for cheap. as for getting out the screws that hold the rotors, get a slightly larger screwdriver bit and then hammer it into screw, then use a socket wrench to crack the screw. (or the next time the fit is at the shop with the wheels off, have the shop "Crack" the screws for you.
~SB
Old Jun 22, 2013 | 10:05 AM
try google search for more hits. Example: type in below
site:https://www.fitfreak.net/forums brake pad
Old Jun 22, 2013 | 10:16 AM
Bisquick's Avatar
Personally, I think the brakes on these little cars are weaker than watered down PBR.
But that's just my take on things.
Stick with stock if you liked them though.
-bix
Old Jun 22, 2013 | 12:58 PM
jimsmith101's Avatar
rotor diameter
anyone know what the front rotor diameter is?
I have a EU model Fit in the US, need to replace pads and rotors. already have the pads, rotors are pretty expensive to ship from the EU.
AFAIK, the rotor diameter for the EU version is 258mm (see the link for exact specs
FRONT Brembo Brake Discs Honda Jazz 1.4 Hatchback -- [2008-2011] | eBay)
Old Jun 22, 2013 | 01:29 PM
2009 Fit Sport, Front rotor size: 262mm Diameter x 21mm thick
Old Jun 22, 2013 | 01:32 PM
ok cheers, a little smaller then
Old Jun 28, 2013 | 05:43 AM
ac9999's Avatar
CrystalFiveMT
Aug 21, 2015 04:49 PM
SevereService
May 18, 2014 12:29 PM
Gregg
Oct 7, 2013 01:19 PM
SennaVsProst
23
Feb 8, 2008 04:33 PM
coldstorage5
Dec 23, 2007 01:14 PM
