help A/C smell
Old Jun 30, 2013 | 02:39 AM
1toughfit's Avatar
help A/C smell
Hi
I have 2010 fit sport auto with 33000miles on it.
I drive about 1000miles a week...
I get old swimming pool smell from the A/C whenever I hit the gas pedal..
Does anyone know whats wrong with it?
I will be taking it to the dealer in couple days, but I like to know before I go to stealership....
Old Jun 30, 2013 | 05:00 AM
loudbang's Avatar
Try replacing the in cabin A/C filter. It's on the upper side of the A/C blower unit you can get to it by dropping the glove box door.
There are a few threads on how to do it .... have a look around.
Old Jun 30, 2013 | 09:53 AM
doctorz's Avatar
There are some other threads about musty A/C smell. In my case I finally figured out that the evaporator core was freezing up. I didn't realize this for real until I had the car on a long distance trip. But I wonder if it was happening on shorter trips, which meant that the moisture in the A/C was freezing up, then melting, and that's what was causing the musty smell. The dealer just figured out that I was low on refrigerant, and flushed and refill the system. I've seen others report the same thing. Regardless, try running the fan with the A/C off for a few minutes before turning the car off to dry everything out and see if that prevents the musty odor.
Old Jun 30, 2013 | 10:58 AM
Cutriss's Avatar
I did this last night and I'm not mechanically inclined in the least. Won't take even five minutes.
Old Jun 30, 2013 | 12:34 PM
Brain Champagne's Avatar
Empty the compartment first or your crap spills all over the floor. That's about the hardest part of the whole process.
Old Jun 30, 2013 | 06:22 PM
CasualFitOwner's Avatar
What I did to reduce the moldy like smell:
When you have cabin filter out, spray Lysol like disinfectant into the blower( i.e. spray into where the filter was) while you have the A/C on with fresh air. To prevent wetting too much, spray for about 10 sec, wait 30 sec and repeat. When done, put in the cabin filter and with A/C on, but with air on recycle, change the temperature setting to max heat. This is to help dry the evaporator core. Keep it on for a while, then turn off the A/C, change to fresh air, and keep the heat on for a while.
I do this whenever wife complains about "weird" A/C smell.
Old Jun 30, 2013 | 07:14 PM
Steve244's Avatar
and leave it on "fresh air" when you park it. "recirculate" doesn't allow the evaporator to dry out as well. Mildew loves warm wet places.
Old Jun 30, 2013 | 09:27 PM
1toughfit's Avatar
thank you everyone for help.
When I bought mine at 30k miles, it already had new air filter...
I think something in the pipe getting freezing too...feels like my nose gets freezes whenever I smell this..
Hopefully Wed trip to stealership fixes the smell..
If not, should I put carbon air filter?
2009fitki
Oct 12, 2016 03:05 AM
Sonnington
Aug 23, 2015 03:25 PM
colnago
Feb 26, 2015 10:53 PM
sneaky_flute
Jan 19, 2014 08:29 PM
BlacknBlue
Mar 4, 2007 07:46 AM
