2nd 12v accessory socket install
Old Aug 18, 2013 | 08:50 AM
over40pirate's Avatar
Not being able to use my cup holder that is in front of the 12 volt accessory socket, I mounted a second one inside the upper glove box, on the left side. Bought a fuse adapter, that allows you to add a second fused circuit to a fuse socket.
Worked great. Now I can keep the GPS plugged in and stored in the glove box, and when using, can still use the cup holder. Nice (NOT) design Honda.
With all the great engineering they put into a car, it's a shame they miss the boat, on some small details. Like the sunvisor, that when turned for side window use, is about 2" too high to be effective. If the mounting bracket, had a different angle it would work fine.
Old Aug 19, 2013 | 06:54 AM
specboy's Avatar
I have no issues with the 12v Adapter and my garmin. I can still use the cup holder with no issues.
Do you have photos of the install (or at least the completed installation?)
I do agree on the visor and using it to block side sunlight.... ugh, they should have just made it fixed.
~SB
Old Aug 19, 2013 | 10:19 AM
yah, i have a flush mount dual USB adapter and no issue with cup holder.
just get one of these and a mini USB cord. one for your nav, another micro USB for your smartphone. walla.
Amazon.com: Griffin Powerjolt Dual Universal USB Micro Colors May Vary: MP3 Players & Accessories Amazon.com: Griffin Powerjolt Dual Universal USB Micro Colors May Vary: MP3 Players & Accessories
Old Aug 19, 2013 | 10:20 AM
btw, amazon sells right and left angle mini USB cables too.
Old Aug 19, 2013 | 12:09 PM
My camera is down, so no pic. I just bought a lighter socket, and drilled a hole in the side of the upper glove box for it. Then bought a fuse adaptor to add a circuit. The adaptor made it easy. Hardest part, was getting the damn, miniature fuse out. Be sure to select a fuse, that is only on, when the key is on.
Here is a link to it. Auto Zone might carry them as well.
2X Add A Circuit Fuse Tap Piggy Back Blade Fuse Holder TIM2 | eBay
Old Aug 19, 2013 | 12:18 PM
i can visualize wat you did.
btw, i use needle nosed pliers to pull out the minifuse.
Old Aug 19, 2013 | 07:53 PM
specboy's Avatar
I used a similar add-a-fuse and the supplied Fuse Puller in the Fusebox when I Did my Valentine1 Hardwire installation (linked in my sig). I'd like to take apart one of the USB power adapters (got a dual one for standard and 2.1A, aka iPad, connections) and see how best to flush mount those sockets next to the standard 12v accessory. Then install a single USB up on the dash by the a-pillar window for my gps. Fewer cords and I'm sure I'll install other items there in the future.
~SB
Press Fit
Feb 12, 2018 09:03 AM
amszterpeter
Sep 5, 2016 02:45 PM
Corbet
Dec 30, 2015 06:02 PM
CIOWN
Oct 10, 2014 12:34 PM
wedgecon
Feb 17, 2011 11:03 PM
