Engine Gurgle
Old Sep 16, 2013 | 08:43 AM
slam101's Avatar
Engine Gurgle
Hi,
I'm looking for some help. Recently, My engine makes this gurgling sounds. It is a constant gurgle that's easier to hear when it's idling. The gurgling completely STOPS when the AC compressor cycles ON. I'm racking my brain trying to figure out what it is. I've tried "burping" the coolant and recharging the AC. So far, nothing has worked. Any help would be appreciated. Thanks!
Old Sep 16, 2013 | 10:54 AM
Steve244's Avatar
Does it sound like liquid? Check the coolant level. There's an overflow tank attached to the radiator between the cooling fans. This should have fluid in it between the low/high marks. If this got low it may have allowed air into the cooling/heater system. Once you're sure the coolant level is correct, there may be air in the heater core. Turn up the heat to high and let it run a while, this should allow trapped air out of the heater core. If the coolant level was low, keep an eye on it, this normally shouldn't drop that much. Might be a leak.
Could be refrigerant, some refrigerant continues to flow after the compressor shuts off for a while (seconds?) Turn off the A/C for a few minutes to rule this out. Shouldn't be a problem either way.
But check your radiator coolant level. If this gets too low it could damage the engine. By then you'll have the "HOT" indicator on but it may be too late...
Old Sep 16, 2013 | 11:06 AM
slam101's Avatar
hi steve,
Thanks for your reply. I've checked the coolant level in both the reservoir and radiator and topped off as necessary. I've tried bleeding the air out of the coolant by running the car with the radiator cap off and heat on high. Regarding the AC, the weird part is that the noise actually stops when the AC is on. Any other ideas, any help would be appreciated. Thanks!
Old Sep 16, 2013 | 11:32 AM
Steve244's Avatar
That's it for burping the cooling system.
Unless it's some weird drive belt noise that sounds like gurgling, I have no more ideas...
cakacon
Mar 2, 2018 12:02 PM
willfit07
Nov 21, 2016 05:25 AM
frantic_2003
Jan 22, 2015 09:23 AM
ishcm
May 3, 2014 05:06 PM
Krystyne
Sep 29, 2005 07:30 PM
