Function and Form sway bar endlink troubleshoot
Old Jan 14, 2014 | 01:24 AM
davidtmnguyen's Avatar
So I have the function and form type II coilovers in my car which are awesome but the sway bar endlinks have been rubbing and making a clunking noise when I turn towards the right, I made sure to make it even with the other side but I'm not sure what else I can do, anyone else have problems with this?
Old Jan 14, 2014 | 11:19 AM
palos's Avatar
First, I'd disconnect the endlinks to verify that they are the source of the noise. Then look at the condition of the sway bar bushings, endlinks and upper mounts, and replace if necessary.
Are you certain you installed the endlinks properly, i.e. the right direction? Are the endlinks rubbing against the spring perches or the coilover tube/assembly. If the former, you could raise them. It sounds like you didn't have the car corner/cross balanced, but instead set the spring height for cosmetic appeal.
Old Jan 14, 2014 | 05:14 PM
I messed around with the endlinks today and extended them a bit more and the noise went away. Thanks for your feedback!!!
appleica
Dec 6, 2012 03:26 AM
harispirzada
Apr 28, 2009 09:53 AM
lilcat
California - Bay Area Community
Mar 11, 2008 09:36 PM
lilcat
13
Mar 7, 2008 01:37 PM
WhatFreshHell
May 23, 2007 10:26 PM
