Roof Storage Question
Old Apr 5, 2014 | 05:46 PM
xuclarockerx's Avatar
This might be a dumb question but I have a 2012 base model...do I need to install permanent roof rails to store anything on the roof? It seems like it to me, but I don't know if there's anything more simple or temporary. It's for a trip next weekend.
Old Apr 6, 2014 | 12:46 AM
DrewE's Avatar
Several companies (including the usual suspects, such as Thule, Rola, Yakima, Rhino, etc.) make roof racks that clip onto the Fit. You don't need to install permanent tracks/rails to use them.
I haven't heard of any rail kits specifically for the Fit, though it's certainly possible to install various generic/nonspecific ones. Indeed, there are one or two threads here about the process. Properly installing rails is a lot more work than using the clip-on rack models, however; and improperly or poorly installed rails could cause all sorts of problems (such as leaks in the roof, damaged side curtain airbags, or paint damage leading to rust.)
Old Apr 6, 2014 | 03:15 PM
Thanks. If you have a moment, can you recommend any particular clip-on models? In the meantime I'll try to do my own research.
sullz
Dec 4, 2016 04:55 AM
hydrocynus
Mar 3, 2014 02:53 PM
fitjoe
May 2, 2013 05:42 AM
Crusty Crayon
Apr 18, 2012 07:13 AM
pandayun
Jan 23, 2012 02:49 AM
