All speakers out -- no audio.
Old Mar 30, 2015 | 11:17 AM
Xdeciph16's Avatar
Hi all,
I was hoping you could help me with my audio issue. I have a 2009 Honda Fit Sport w/ Navi. My front left tweeter was out so I opted to buy a new set of speakers and tweeters to give the Fit a little upgrade (I know updating the head unit is typically better, but I like the stock Navi... for now). I ended up buying the Metra 72-7800 Speaker Connector Harnesses for Select Honda Vehicles to hook in my Infinity Primus speakers.
Harness Adapter:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Front Speakers/Tweeters:
Rear Speakers
Amazon.com: Infinity Primus 6.5" 2-Way Loudspeaker-Each (Black): Electronics Amazon.com: Infinity Primus 6.5" 2-Way Loudspeaker-Each (Black): Electronics
I am a noob at this kind of stuff and just dabble every once in a while, but I hooked everything up (only replaced the rear speakers because my fronts and tweeters don't come in until this week) and the speakers sounded great. It lasted for a few half hour trips and then on my way home all 6 speakers just stopped. There is still power to my Navi/HU, but all audio has ceased to exist. I'm not sure if I could have shorted the system, maybe knocked loose some wiring, or what. Any help would be appreciated, thanks!
Stephen
Old Mar 30, 2015 | 02:54 PM
DavefromCA's Avatar
I'm sure someone more knowledgeable will chime in but my first guess is those speakers are pulling too much power and overloading the head unit. You may need to look into a new head unit.
Old Mar 30, 2015 | 03:05 PM
MNfit's Avatar
Did you check fuses?
Old Mar 30, 2015 | 03:44 PM
xxryu139xx's Avatar
Did u solder?
Old Mar 31, 2015 | 11:34 AM
Xdeciph16's Avatar
Thanks for the suggestion, that was one of the things I was considering, but have yet to look into. When I get the chance, I plan on re-checking all the wiring and making sure there is not a short somewhere.
Old Mar 31, 2015 | 11:35 AM
Xdeciph16's Avatar
Another thing I have considered, do you know the best place to find a fuse diagram for the Fit? I was googling it yesterday, but didn't have too much luck initially.
Old Mar 31, 2015 | 11:36 AM
Xdeciph16's Avatar
Did u solder?
I used a harness instead of soldering.
Old Mar 31, 2015 | 03:09 PM
p220sigman's Avatar
Losing all of the audio at once would tend to indicate a problem with either the harness that contains the speaker wires or the headunit itself. If you shorted something, it is possible you took out the amp in the HU. Usually you get lucky and blow the fuse, but I've see it happen where the amp was cooked. Check all the fuses first and then go from there.
Old Mar 31, 2015 | 03:33 PM
xxryu139xx's Avatar
U will still have to solder the harness to the radio harness. If u just taped it it will fall off.
Old Mar 31, 2015 | 04:27 PM
Xdeciph16's Avatar
Thanks for the advice, I checked out the fuses and they all seem to be in good shape.
Xdeciph16's Avatar
Oh all right, thanks. The positive and negative leads from the harness to the speaker seemed very snug. I'll look into this.
Old Mar 31, 2015 | 04:30 PM
Xdeciph16's Avatar
All right all, thanks for your help in initially diagnosing this issue! Here is what I just discovered...
I unhooked my left rear speaker and then turned on my engine and presto I had audio again. Granted, it did reset all of my presets on my radio, but I can live with that. So based on that information I am thinking either a short or the new speakers are drawing too much power so I'm going to test these speakers out and hold them away from any metal that could cause a short and try to play my stereo for longer than the two 30 minutes segments that it lasted last time.
If you all have any suggestions based on this new information I'm all ears, thanks again!
Old Apr 1, 2015 | 05:26 AM
Frenzal's Avatar
Happened to me in my Accord: passenger speaker was causing a short (never found exactly where!) and the radio would not allow any output to protect itself. I removed the door panel, repositioned the speaker, and everything has been OK since.
As for the power, if you have 4 ohms speakers (I think car stereo are made for 4 ohms speakers), you will be fine. You would have a problem if you used lower resistance speakers (2 ohms for example).
Old Apr 1, 2015 | 08:26 AM
Xdeciph16's Avatar
Thumbs up
Awesome, thanks for the input! I still need to check to make sure they run all right for an extended period of time without being put near any metal. However, I think I read something similar that the stock stereo was made for 4 ohm speakers, but the ones I purchased were actually 3 ohms...
Old Apr 1, 2015 | 11:41 AM
DavefromCA's Avatar
Glad you may have found your problem. However, you should check all of the specs of the speakers you put in, as well as the head unit specs. That can tell you right away if you are overloading the unit.
Old Apr 1, 2015 | 12:59 PM
Xdeciph16's Avatar
Thanks Dave, I appreciate it. Do you all happen to know what the head unit specs are for an 09 Fit Sport with Nav? I was able to find some stuff, but not necessarily all the numbers I would have expected.
kmschwem
Feb 16, 2020 03:59 AM
SilverEX15
Jul 24, 2015 04:10 PM
Xdeciph16
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
May 12, 2015 07:54 PM
Bogdan
Apr 27, 2015 12:37 PM
zerogeek
Oct 1, 2010 04:05 PM
