Safe position to attach decoration to dashboard?
Old Apr 26, 2015 | 09:49 AM
fortnight's Avatar
Question Safe position to attach decoration to dashboard?
So I got a little die-cast Fit to put on the dashboard of my actual Fit (probably attached with velcro).
I was going to put it on the passenger side, right above the glove compartment, but then I noticed the SRS airbag logo. I assume this means the airbag deploys from that location, and that it wouldn't be a good location for the toy car.
Is this correct, and is there anywhere else on the dashboard that would be unsafe to attach a decoration like this?
Thanks!
Old Apr 26, 2015 | 11:09 AM
Skeletorspimpcane's Avatar
I'd shoot for directly behind the center vents on the dash. Fairly flat and not textured.
Old Apr 26, 2015 | 10:35 PM
DrewE's Avatar
You are correct in what you surmise about the airbag.
Above the vents would be OK, as would between the vent/radio pod and the gauge cluster pod. If it fits, you could perhaps stick it on the ledge between the two glove boxes, though that's a prime sunglasses stash location.
bhacker1994
Apr 20, 2016 12:25 AM
lovelyfit
Jan 12, 2012 06:14 PM
lovelyfit
Mar 13, 2009 10:47 PM
lovelyfit
Mar 3, 2009 12:34 AM
bosshogg
Aug 31, 2008 05:17 AM
