Lower left rear suspension problem
Old Jul 11, 2015 | 06:23 PM
Philip0021's Avatar
Hi guys. Why is my fit lower by almost. .5inch to the left rear side than the right. Tried to get coilovers but still the same thing. Lowered by .5inch
Old Jul 12, 2015 | 02:14 PM
connor55's Avatar
Are you on flat ground? These differences are pretty much normal. Especially with the rear being so light, the smallest amount of load or uneven ground can make a difference even on stock suspension.
Old Jul 13, 2015 | 04:46 AM
Black3sr's Avatar
Move the girlfriend to the other side.
Old Jul 13, 2015 | 06:12 AM
eternal_fantasy's Avatar
Because the fit has significant left weight bias. Depending on your Coilover spring rates, you can calculate how much spring perch height adjustment you need to compensate for the bias.
With my 5kgf/mm front and 2.4kgf/mm rear spring rates, and a weighted 65.4% Front - 52.5% Left balance, the left side needs +7.59mm Front and +14.13mm Rear for the car to sit flat with an even LF/LR corner weight percentage.
Old Oct 6, 2023 | 02:16 PM
B1391's Avatar
Yeah but you can't adjust stock suspension can you?? Mine does the same thing on the passenger side rear sits lower than driver side rear
Old Apr 11, 2024 | 05:16 PM
FionatheFit's Avatar
I just noticed this on my 08 sport. Could this be a sign of failing rear shocks?
Old Apr 11, 2024 | 10:22 PM
SiXiam's Avatar
I just replaced my rear shocks on Sunday. I didn't notice any height issues. I noticed that the car was really jumpy and flexing at higher speeds. Then I noticed a clicking/clanking coming from the rear passenger side.
The rear drivers shock, top was rusted, but it still retracted and bounced back. The rear passenger side would not bounce back and had similar rust.
Now the car has a much more enjoyable stiffer ride. I'm sure my front struts could also use replacement, but I highly recommend doing the rear first. I think I can go a few more years on my 09 without changing the front.
utsug
Oct 6, 2023 02:15 PM
lasncohes
Sep 12, 2018 01:35 PM
De36
Jun 24, 2015 12:52 PM
MarkyMark
Oct 21, 2008 08:20 AM
ghostfit
Feb 9, 2008 03:07 PM
